JasonS
- 126
- 63
- Eastern SD
8000 hours is about double what has been reported on the internet:The clincher was the Oliver Farm tractors with 7000-8000 hours without a rebuild. Same basic design and compression ratio. The difference is that the Oliver is governed at 2200 or so.
http://www.steelsoldiers.com/deuce/73830-oliver-2150-multifuel-4.html
but most of the trouble in the tractors seems to be related to leaking fuel injectors.
The multifuel has a 22:1 compression ratio whereas the tractor is ~18:1. As you raise the compression ratio, the combustion pressure rises faster and higher. This causes higher strain on engine parts.
The TMs state 2200 is maximum crusing rpm.
