bgekky3
- 2
- 0
- Huron, Ohio
For the last week I have been working on changing the 9.00s for 11.00s on one of my trucks. It was slow going at first. I thought I would comment on what I learned so far. I searched for info on how to do it and talked with my father to make it happen.
#1 Get a duckbill/tire hammer. It makes removing the tires so much easier. I tried a high lift under the front bumper with a sledge and a truck and a high lift with a sledge and could not break the bead. If you stand on the tire and hit in between the bead and the rim you can break the bead fairly easily. I also used dish soap, WD40, Gasoline, and silicon to help lube the tire to remove it from the bead. WD40 after a few hours seemed to work the best.
#2 Bribe your friends with beer and brisket. Trust me it helps a lot.
#3 Make sure you are safe when airing up the tires. One of my friend's cousins was killed by a split ring (I know sounds like and internet story but it is true, he would not help me even with the brisket and beer). Make sure you have a clamp on air chuck and are out of the way before you add air. I don't have one yet so I have not aired up the assembled tires yet. Use a cage or chains when you do add air. I will add those pics when I air up the tires.
#4 If you borrow tools such as a chisle, make sure it does not have deformed metal around the edges. If you hit it the metal might break off and go in you eye. When you go to the hospital to get it removed you will be hating life. Also wear safety glasses just in case.
I think part of the MV hobby is keeping the old methods alive. No tire shop around me wanted to touch a split ring. I also take pride in doing my own work. It is easy to throw money at a project and call it yours, but it isn't really yours unless your DNA is on it.
If anyone can add any safety related points to the post feel free. I want to finish the job without hurting myself in the process.
