wsucougarx
- 68
- 48
- Washington State
Looking good Scott!!! Man, one of these days I'll back to my deuce projects.
Looking good Scott! It is what your truck needs is more lights! LOLhahaha mike. projects on which deuce!!!!
added side ally lights. 100w 24v bulbs. need to order more as I used my last 2 i had bought awhile ago. same lights as my backups and i plan on hooking them up to the same toggle as the backup lights
View attachment 422328View attachment 422329
also for the bed of my truck trying to figure out where to mount 1 more fuel can. and then mounting a taller ammo can that holds all my straps. I may be able to fit it in the toolbox. havent tested it.
got a 3/4in impact gun from dan! the nsn says its a kit for the m1a1.
was going to work on the chock holder but decided the garage needed cleaned more then that hahah.
The rim/tire combo? Are those modded original deuce wheels? Any rub on turns?hahaha mike. projects on which deuce!!!!
Would like to know more about this. Thanks.The holes along the bottom rail, indicate that this truck once served some sort of portable mess hall function?
where can I get one?View attachment 419746View attachment 419747View attachment 419748View attachment 419749
new 2in hitch with 10" drop and 2" ball.
also a front bumper step added
The metal plate is the standard behind the pintle hook two inch square trailer hitch! The plans are here on steel soldiers. The drop down hitch adapter was a find at the four wheel drive swap meet at the fair grounds! Shouldn't be to hard to find on line!where can I get one?
Right on - the 395s are just about the beefiest looking tires I have seen that seem to fit on the unmodified deuce wheels.those are 395's on standard deuce rims with a tube inside a 1200 x 9 tube.
Boo Scott BooSo I sold her... but start of a new 5 ton project. Pics later this week
......that's depressing.......hmmm.So I sold her... but start of a new 5 ton project. Pics later this week
