Well the transmission is back in, and works like a charm. I had some trouble getting the clutch linkage adjusted right....it didnt work like in the manual, if i put it one spline to the rear of the centerline, then the center of the pin wasnt 3 1/4" from the bellhousing...so i just put it 3 1/4" from the bellhousing and adjusted the connector rod. Putting the hubs back on was a trick for me so i wont say how i did it, until im sure they are set right. once i drive it around the block a few more times i will jack it up and check the bearings again. Anyways heres a few pics..sorry for poor quality.
the last pic is my TM workstation just so all the TM guys can see i really used one LOL
