cam7002
- 0
- 0
- Raleigh, NC
'mornin', folks. M1009 CUCV, I did a transmission filter change and a transfer case drain last night. As I was filling the transmission, I kept checking it each half quart. It keeps showing that the fluid is way low in spite of a significant amount of fluid in there.
I checked to see if it was simply sieving out the bottom, and it is not. I triple-checked the manual for the tranny capacity, and the manual says it is 4 quarts.
"One of the manuals, TM 9-2320-289-20, has an error with regard to the transfer case and transmission fluid capacities:
Biennially Trans- Remove oil pan, drain fluid, replace transmission filter, install pan, and refill with new Dexron II fluid. DO NOT overfill (see paragraph 5-2). Transmission service capacity is 4.0 quarts (5.7 L).
"Biennially Transfer Change fluid by removing drain plug and allowing fluid to drain, then refill with new Dexron II fluid. Transfer service capacity
is 5.0 quarts (5.7 L)."
Obviously, 5.0 quarts and 4.0 quarts do not both equal 5.7 liters.
So I have four questions, two for the tranny and two for the transfer case.
1. What is the fluid capacity of the transmission?
2. Why might it be showing low after I put in more than four quarts?
3. What is the fluid capacity of the transfer case?
4. Is there a cool way to check its fill to see how full it is?
Thanks for the help. First time I have done either and I have another one that needs the same.
