- 4,053
- 6,815
- 113
- MA
Thought I had a link to the washers. I dont see the harm in running a galvy washer personally
Howdy,So before I turn into the incredible hulk on the parts later... if the well nut is rotted, can the whole assembly just be pulled out of the tank, or will I have to remove the metal pieces sticking out, and push it backwards into the tank to remove?
When you guys installed the bulkhead fitting, what are you torquing the nut to?
Howdy,When you guys installed the bulkhead fitting, what are you torquing the nut to?
