I've been buying it by the gallon. No propane in that!The can used to have propane in it for a propellant - perhaps that's what the engine is starting on instead of the oil.
That is correct: WD-40 Company and Product HistoryYou have it right except for the 40.
That stands for the 40th formula they tried before they got it right. They had 39 before that that didn't do what they wanted.
You would think?!If its a new formula, shouldnt it be named WD-41?![]()
So if they got it right at 40 and it's still right but just new.
Maybe it should be WD-40-A
Been there, tried that, didn't work worth a damn, not from wood anyway. Their web site also says that the Stoddard Solvent speculation is incorrect.The liquid in WD-40 is a petroleum distillate, Stoddard solvent. It works well for removing cosmoline.
CMSGT......... I believe you are correct in that they did change the propellant in WD-40. The new stuff does not seem to work as well as the old stuff. The formula for WD-40 has not changed just the propellant in the aerosol can. I have been using PYROIL starting fluid for years and have had no problem. However a lot of folks do not know that starting fluid generally comes in two strengths. Regular and Premium. I use the premium as it has a higher ether content and gets the job done quicker. By the way PYROIL starting fluid has the required lubricants in it to minimise the wear on the internal parts when using the product.
ADDED LATER:
Valvoline Pyroil Premium Ether Starting Fluid 11 Ounce SFR-11 America's Farm & Home Store
Some of the off the wall brands do not have the lubricants in them so beware.
