Big Dumb Truck
- 0
- 16
- Birdsboro Pa.
The vibration happened while cruising and a steady speed. It would surge at a steady rhythm from being nonexistent to very noticeable. I crawled around under the truck looking for anything that felt different. Note that I have been working on the deuce almost daily for about four months and I have become quite familiar with all of its problems. I found that the propeller shaft entering the rear rear had almost 3/16" of play in it up and down, and almost 3/8" Front to back. The other rears have some play also but not as bad.
I took the gear carrier out of the rear. I built a stand to sit it on. Then I began inspecting the gears and bearings. Only the pinion bearings were bad. The rest of the bearings were in great condition. I tool the top end apart per the TM instructions. I took the old bearings and races to Philadelphia Roller And Bearing, and they had my replacements in stock. I got new seals too.
I have driven the Deuce three times since and the vibration is gone. I still have other vibrations rattles and other noises to contend with but the scary one is gone.
