rustystud
3,394
Woodinville, Washington
Can you grind them off and then punch them out....?
If you punch them out you will destroy the "captive nut". The bolts are 3/8" fine thread. So when they get rusty you have a lot of threads to "unrust" ! I would try some "PBS" spray or better yet "Evapo-Rust" . Just pour some out around the bolts and leave it for a day.
bosephjarrows
Oxford/ NY
Did an oil change.. Only got about 2 gallons out of it. Every time I checked the oil it was high on the stick then I realized it says check 1 minute after running.. Also changed the exhaust stack from short chrome to a taller one. IMG_20150814_134747727_HDR.jpgIMG_20150814_134747727_HDR.jpg
frank8003
4,990
Ft. Lauderdale, Florida
windshield wipers air supply
Removed the windshield wiper air supply valve and replaced two times. Heater vent controls and engine pre-heater controls ALL in the way. Like I said, 2 times.
She with scary socks went back to work, left me again.
Upside down and backwards is lots more difficult with the consequences of age. So when you get ready to replace the fasteners one finds One can't get the head around far enough to see thru the bifocals! Like being useless.
But I was actually just finishing the job of the remote reservoir sight-glass I wanted.
SteveKuhn
Hasbrouck Heights NJ
"...Upside down and backwards is lots more difficult with the consequences of age..."
Similar syndrome to replacing the air pressure gauge feed hose. Even with the passenger seat out, soft top untied and up, and feet against the headache rack.
Steve
rustystud
3,394
Steve
You must learn to become "one" with the truck ! Then and only then can one achieve success ! rofl
SRB1976
9
Hanna, Wyoming
Had the local tire shop swap the worn out left front tire for the brand new spare and ordered a brand new tire for the right front. The rear tires are still good. I'm starting to eliminate the leaky CTIS components from each wheel.
