Ha Ha, Touché. Never thought of it that way.Stig got a purse
Sent from my iPhone
Sent from my iPhone
Found out I have fuel in my oil. Drained oil, will fill it up with fresh oil and try to see the dilute rate. May need some help from all of you deuce masters on this.
Sent from my SM-G900V using Tapatalk
Leaking injector is a possibility, but you'd probably notice the miss at idle.Your drivers side springs may be your steering box leaking on it. Unless you know it is diesel. My fdc is bypassed and heater is disconnected so time for research on other places fuel can enter oil.
Fuel shutoff valve shaft o ring still might be a possibility.Your drivers side springs may be your steering box leaking on it. Unless you know it is diesel. My fdc is bypassed and heater is disconnected so time for research on other places fuel can enter oil.
How do you check for that? (Leaking injector)Leaking injector is a possibility, but you'd probably notice the miss at idle.
Sounds like you need to come get this m109 so you can keep trucking while you figure that out![]()
There are a number of things to look for. Rough idle, excessive smoke, missing when accelerating.How do you check for that? (Leaking injector)
Sent from my SAMSUNG-SM-G930A using Tapatalk
Wood all the way.pulled the trailer bed off my bobbed deuce and modified a 14' flatbed off an old dodge d500 truck to fit. cut 4' off the end and turned vertical to make the cab protector. I'm still trying to figure out how to finish it out. haven't decided between expanded steel, or maybe lower half with wood then some steel bars for the top half.
View attachment 617288View attachment 617289View attachment 617290View attachment 617291View attachment 617292View attachment 617293View attachment 617294
If it works, beers on me! Or scotch.Shop vac with nozzle will get them out
Sent from my SCH-I545 using Tapatalk
I was at the submarine base. LOL! I remember some local papers (tabloid types) thought there was a secret underground submarine base (500km from Port Augusta). Anyway, I worked at the satellite monitoring facility. If you ever saw the movie Wargames & remember the controller at NORAD mentioning BMEWS, that was us. Ballistic Missile Early Warning System.G'day everyone,....
Your right, we don't have a 2'nd Amendment down here but we sure do need one!
What happened in Tassie was really bad (and show why people should be able to carry) and followed by a tyranny inflicted on law abiding people,....
Also a case in point as to why you should NEVER let you guns be registered.
No, my Deuce is unmodified, it is still left hand drive.
Woomera eh?
Did you work at the missile range perhaps?
Aussie.
