jbayer
- 10
- 18
- St. Aug., FL/ McGrady, NC
Fine job.I took two 3 step stands I got from from Sportsmans Guide, cut them apart, welded them back together as a 2 step stand, and a 4 step stand that I can use to get in the back of the Deuce. A little heavy being steel, but that's all I have right now. Not quite sure how to use the 2 stepper yet.
CongratulationsI'm finally winning.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
That's an interesting finish you got there on your slab, dmetalmiki. It might be common your side of the pond, but I've never run into it here. Looks like it was raked in two different directions; did you place the slab yourself?So today and most of the night we worked to finish the tasks on this truck I bought back..here are pictures of the progress..Complete oil changes,,A pre lube engine oil pump fitted.. tomorrow the other front wheel bearing re pack and brake adjust..Weld the slipping wheel conversion wheel studs again. I Am SO tired..and aching from this necessary work..at my age,,,ho hum..
What is the hose going to the differential all about ? Also what is that canister by the differential with the dangling wires all about ? The pictures came out pretty fuzzy and I cannot make out all the details.So today and most of the night we worked to finish the tasks on this truck I bought back..here are pictures of the progress..Complete oil changes,,A pre lube engine oil pump fitted.. tomorrow the other front wheel bearing re pack and brake adjust..Weld the slipping wheel conversion wheel studs again. I Am SO tired..and aching from this necessary work..at my age,,,ho hum..
