deuce2
- 0
- 0
- carson, nv
I just got the truck in october. I'll let you know the same.I was hoping to find that same historic info for my Deuce too. I'll let you know if I find anything.
www.eriksmilitarysurplus.comThank you, and I went to the P version and the L-N3002AE parts not listed in there.
Anybody know where to get a Deuce alternator regulator?
Thanks for the tip. I'm not familiar with anti-seize, but I'm going to look into it now.That's why I always use "Anti-Seize" on my bolts when the other part is aluminum. That way there is no corrosion and the bolt will not seize to the aluminum. On a lot of newer alternators they install a steel insert on the mounting ear to prevent this from happening.
Very nice!Finished the install of a PTO with direct mount pump onto the rebuilt tranny. Some floor mods will be required but no frame problem.
This is the same PTO as the 939 series.
That is about a 4 cu.in/r pump, turns 1.1 x engine rpm.
It doesn't get any better than that; excellent!Finished the install of a PTO with direct mount pump onto the rebuilt tranny. Some floor mods will be required but no frame problem.
It'll never do you wrong, or at least not to my knowledge (it's kind of a fastener no-brainer). Even when you don't have dissimilar metals.Thanks for the tip. I'm not familiar with anti-seize, but I'm going to look into it now.
What's that liquid glass at the end of the vid, frank8003; brake fluid (part of the install)?fixed the brake lights, installed tell tale LED
It sure would be nice to not have to download someones video to watch it.fixed the brake lights, installed tell tale LED
Yes I saw that. I was curious if any local parts store would have one?If it's multi fuel, any of the suppliers should have them(big mikes motor pool, tnj Murray ,Memphis equipment etc.)
I've tried all the original part numbers and nothing comes up. Wasn't shure if there was an aftermarket part number someone has found.Yes I saw that. I was curious if any local parts store would have one?
I'm curious if this is actually the correct tag for my truck. It was laying on the floor of the truck. There is about 20 other m35a's in the same yard. I wonder if someone pulled this tag off another truck. Not sure why they would though. Is there any other way to find the year on the truck?
Holy crap that sucker is pricey...291959827622
Type that into egays search
