Slate
378
Ozona Texas
I'm tackling the dreaded airpack rebuild? I think it is harder than removing and working on the Hydrolic head. Look at the fun that was in it? Can was still good but nasty. The little end cap on piston was the hardest part. I cut some groves in my snap ring plyers and they held the little snap ring booger. There were a lot of small issues I'm amazed it was working at all. 6 cans of brake cleaner, and I never did cus. Honest. It goes back on in the morning.IMG_20200327_094225331.jpgIMG_20200327_094541935.jpgIMG_20200327_174128489.jpgIMG_20200327_123903013.jpgIMG_20200327_180658076.jpg
Sent from my moto z3 using Tapatalk
Tracer
14,440
Hawthorne, NV.
the arms are 1x3 bar stock and are heavy. Thats why they are temporary wired like that, so it doesn't bonk me in the head while Im doing the 45 mounts to the frame by the spring perch.
Dave. Keep us posted on how it works. Heck it's still snowing down here in Northern Nevada. 🥶
Dunkeye11
Fairfax, Virginia
Bought some wheel cylinder rebuild kits from Napa PN(45) apparently the last 3 in the system they have the nice strong spring and rebuilt 2 of the wheel cylinders I just removed
Jbulach
2,414
Sunman Indiana
Looking good David! Your probably going to want to X brace, or triangulate, at least the bottom arms in some way. You’ll be amazed at the pushing power of these trucks.
davidb56
1,238
Bonners Ferry Idaho
thats the steel Im waiting for, and the 1" bolts for the other side and 1 1/2" ram pins. They are closed on weekends here.
Slate
378
Ozona Texas
Not sure I want to live anywhere I need a snow plow that heavy. Looks pretty awesome though
davidb56
1,238
Bonners Ferry Idaho
Deep cold snow, and lack of "Free $**t" keeps a majority of the rats in the big cities. Spoken from someone who retired from Stockton and Oakland CA. I actually have a smaller plow on my old F350. This one is for the "10 year" Apocalypse snow drifts on my road.
SCM35A2
3,392
Florence, SC
Cleaned up both trucks & took some pics of the M35A2, also reworked the drivers front wheel. The paint was peeling off in some spots so I took it all back down the metal & repainted it. She cleans pretty good...
Iron Maiden
112
Oregon
Today I finally got around to replacing my knuckle boots. The job also entailed replacing some brake lines. I knew access to my wheel cylinder valves was very poor because it was almost impossible to bleed the brakes. I solved this problem by machining some new wheel cylinder valves from 1/2" stainless steel hexagonal bar stock that were long enough for good access with a wrench.
bachman502
58
Chesapeake, VA
Pulled my cab this week. I’m swapping it out for a rust free nos cab. It was quite a chore. Nobody talks about getting access to the two front bolts that hold the cab on. My new cab has holes already in floor for bolt access.
Slate
378
Ozona Texas
Doesn't like there is much wrong with that cab. Don't trash it. Someone may buy it.
bachman502
58
Chesapeake, VA
It’s has a lot of rust around the passenger side rocker panel. Also once I removed the dash, I found a lot of rust at the top of cab on the interior. I also have a bed I removed that I was selling with some rust. But it’s all about logistics when you try and sell some of these larger parts.
montaillou
858
W.WA
Yep, that's why I like to give stuff away. Let someone else worry about picking it up. If you have the room, consider storing it for a little while and offering it up for free to someone in the "Pay it forward" section. I always look at how some people are looking to restore these things on a budget.
