Elijah95
Certified Rookie
1,246
1,221
Georgia
@Tracer I hit it with the oxyacetylene rig until they were red hot, and quenched with Kroil, then new nuts, double nut method with a washer in between begrudgingly removed them. Apparently someone went wild with Red Locktite
Tracer
14,386
Hawthorne, NV.
Some people use Red Loctite in the wrong place and for the wrong reasons. On my PTO studs I use white Permatex thread sealant. Keeps those little leaks from happening, and I've never had a PTO stud back out. Glad you got yours taken care of.
V8srfun
539
Altoona pa
Took the truck out to dinner with the wife.
Installed oil filter upgrade.
Changed fuel filters.
Thought about the service work I need to do to it like change the ,transmission, transfer case, and axle fluids. Service all of the wheel bearings including replacing the front boots and full front axle service. And fully inspect and repair as necessary all of the wheel cylinders then flush the fluid with fresh dot5.
I also need to replace one of the spring eye bushings (not excited about this).
But it’s so hot out now this will most likely wait until I can work without showering in my own sweat. 33E91313-EC48-406B-B9B4-8EE25A034A3E.jpeg
fleetmech
405
Connecticut
I put some flags on, drove around for the 4th... and became increasingly convinced that switching to ND30 in the trans was a mistake. Its getting very "sticky" feeling as soon as it gets warm. Time to pull that oil out and back to gear oil. A well intentioned attempt, but a failure, at least for my trans.
m715mike
3,922
Montgomery, Texas
Yup, I made that mistake once too...
Iron Maiden
112
Oregon
I am anticipating towing a trailer soon, and thought it would be a good idea to reinforce the trailer receiver hitch that I have already. To do this I reinforced an existing forward cross member with 4" channel. I also fabricated an attachment between the forward cross member and my existing trailer receiver hitch. I sandblasted all the parts and finished them off with Chassis Saver paint and bolted everything up with grade 8 bolts. Everything was fabricated using holes in the existing cross member and trailer hitch.
Picture 1 is the cross member reinforcement
Picture 2 is the brace that goes between cross member and trailer hitch
Pictures 3 and 4 is everything bolted onto the truck
jasonjc
289
Gravette Ar.
I've been doing a lot of stuff over the last few days. Oil change , fuel filters , LED headlights , rebuild front wheel cylinders , replace front brake hoses ,replaced knuckle boots and some other stuff I haven't even thought of yet. Also built a seal driver for replacing the inner axle seals.
cattlerepairman
3,520
NORTH (Canada)
Stared at the coolant dripping..no, running, from the rad support and disappearing in the sand. Maybe one of the rad solder repairs finally gave out. Maybe a hose. I have a spare radiator. Maybe time to replace it....I will find out. WHY DID I HAVE TO SAY OUT LOUD TO MY WIFE ONLY YESTERDAY THAT "THE TRUCK IS FINALLY RUNNING PERFECTLY WITHOUT ANY ISSUES"? Arrggh.
92ramaro
263
Riley, MI
My first Independence day with a Deuce.
Used Daisy to tow a junk motor home to a friends house on the morning of the 4th so we could blow it up and get his annual party started. Didn't imagine that she would end getting so much attention for the rest of the day/into the night from a majority of folks. Ended up taking a bed full of kids for a ride on the back roads a few times, and after night fell, a bed of inebriated adults while we convoyed with a John Deere pulling a crowded hay wagon in front of us.
It was an awesome day for a truck that spent the last 11-12 years sinking into my neighbor's back yard I'd say.
Modiconman
31
Richmond, VA
My Sherman had a good week this week:
  1. re-bled the brakes and topped off the fluid
  2. my first oil change! $125 bucks later :-(. The oil was in great shape though, no sludge and no shavings or metal pieces. The WMO was good enough I felt ok pouring it into the fuel tank.
  3. fixed a stripped-out bolt hole on the compressor. The rear, top left bolt on the casing (where the fuel line bracket attaches) stripped out a little while ago and it's been causing the engine to pick up a light film of oil everytime I drive it. It's been nagging at me for a while, but I have been holding off on the fix since I needed to remove the oil filter cannisters and I knew I had an oil change coming. I drilled and tapped it, and inserted a heli-coil. The operation went smoothly and appears to have fixed the issue. Whew! Feels a lot better know - I hate it when I have those nagging fixes in the back of my mind that I haven't gotten to yet.......
  4. Installed a pyro. I used the most common location (pre-turbo, right where the exhaust turns down). I installed the Aubern digital 24v pyro. With the air filter cannister removed, the access and installation was a snap. I drilled almost all the way through, then fired up the engine and drilled the rest and tapped it 1/8" NPT. I ran the wiring and fired the truck up and watched it work great :jumpin:.
I still need to build a bracket to mount the gauge, once that's done I can get some baseline measurements and turn the fuel up. I have a suspicion that my fuel is low, and I have lots of overhead to get more power out of my engine. We'll see.....
Heres how I mounted mine
Elijah95
Certified Rookie
1,246
1,221
Georgia
Sold a deuce today (not pictured) and got out with a buddy cruising some dirt roads. Last night I built a spin on primary fuel filter kit, changed both secondary fuel filters, found out in tank pump bottom plate fell off... crap, snatch it out, throw in NOS Parker Red pump, modify harness, drop it in, bleed, no leaks check! Fired it up and wow, it added what felt like 40hp and 100 torque by the ol seat meterIMG_1367.jpg
cattlerepairman
3,520
NORTH (Canada)
Sold a deuce today (not pictured) and got out with a buddy cruising some dirt roads. Last night I built a spin on primary fuel filter kit, changed both secondary fuel filters, found out in tank pump bottom plate fell off... crap, snatch it out, throw in NOS Parker Red pump, modify harness, drop it in, bleed, no leaks check! Fired it up and wow, it added what felt like 40hp and 100 torque by the ol seat meterView attachment 805878
Looks like a sharp truck, Elijah !
Sent from my SM-G950W using Tapatalk
Elijah95
Certified Rookie
1,246
1,221
Georgia
Getting some exercise today breaking down tires and wheels to start my G177 project on the truck, thanks to @Welder1 for the advise and safety training. 3 down, 9 to go!
Menaces Nemesis
"Little Black Truck" Conservator
262
Denver, Colorado
... Exactly my same experience with ND straight-weight, plus the added "bonus" of fewer and fewer suppliers stocking ND in viscosities recommended for the 3053A; https://steelsoldiers.com/threads/m35a2-transmission-fluid-change.195206/#post-2279430
