Welder Sam
Glendale, Arizona
Have you tried to adjust them down? Cover the light that youre not tinkering with so you can see exactly whats happening. Ive had some that i cranked up and some i cranked down to get them where I want/need them. May double check with a local that knows the light adj specs deemed correct by your local law enforcement agency fir extra cya. Remember, the mechanics likely didnt spend alot of time on proper headlight adjustment or the driver mayve jacked them higher. Tinker with it and set it how you dig it or at least legal as best as you can
As far as strange, if it gets the results you desire and you like how it looks, who cares what joe schmoe thinks! We each want different things from our trucks.
Just a thought but since height is a problem, have you thought about a cb antenna mirror mount bracket? Theres some potential in that without having to fab mounts or drill into the rig
insanejecke
Sumter/SC
Finlay mounted the passenger finder that I rebuild on the truck late last night. I took a few pics and they turn out crappy so ill post the better of the two ill get more this weekend. finder4.jpgfinder3.jpg
NJDEUCE
New Jersey
I installed two of those Grover stuttertone horns in my Deuce as a replacement for the weak stock horns. They demand attention
Suprman
707
Stratford/Connecticut
I tapped off the horn supply after the solenoid so when I honk the steering wheel horn button they all honk. They sure do demand attention they sound just like a fire truck.
MyothersanM1
19K M1 Armor Crewman
435
68
Culver City, CA
Stuttert horns rock! Almost got one myself!
NICE! I know what you mean! My Nathan P3 grabs the gullet of even the most hardened "text-while-driving" driver.
engineer233
London,Ky
I used a cummins fuel filter base with a 1"x 14 thread pattern. I chose a Luber-finer fuel water separator LFF 8020. This filter is a 15 micron absolute filter. I will more than likely next time use a LFF 90011 filter as it has a bowl so you can see the water. It is also a 15 micron absolute. If you prefer they also offer a 5 micron absolute filter. I made my own bracket out of some scrap aluminum I had laying around. Other than that all of the other stock fittings mounted up perfectly with no mods.
MyothersanM1
435
68
Culver City, CA
-Changed out the front pinion seal on the front axle...
-Changed input shaft seal on the transmission (should've done it last year when I had the darn thing out for the rear main seal:doh::rolleyes:)...
And...
-Installed new Truck-Lite bracket/Peterson LED license plate light.
Robo McDuff
In memorial Ron - 73M819
1,609
Czech Republic
Since October last year (adding anti-freeze coolant)......
:sad: :sad:. ...... NIC ....NADA....NOTHING........:cry: :cry:
and its already mid June. Getting very frustrated here. cute-blue-bird-crying-smiley-emoticon.gif disappointed-smiley-emoticon.gif sad-crying-smiley-face.gif
Would like to say a lot of things about it, but the moderators would bleeb every second bleeping word out.aua aua
