What have you done to your CUCV today/lately? - Part 1
combatmech
Carrollton, Texas
:ditto:Wayne makes a great point, Off Road Design makes repair and strengthening brackets for the steering gear area on K-series trucks. ALSO, Check your air filter housing. Occasionally the wing nuts on mine work loose and that thing makes a terrible racket, especially when doing the high idle warmup. [thumbzup]
Ditto on the air cleaner wing nuts, just found the same thing saturday.
367
Castalian Springs, TN
I have completed the ORD repair/upgrade frame kit install as well as the ORD steering brace.. ( approx 2 months ago ) VERY HIGH quality and well made...
I went with a Redneck ram hydro assist kit as well.. No more issues or weak links with Steering...
:doghead:
CycleJay
Marietta, Ga
Hi guys,
Nothing much lately other than finally getting a AAA card in case of any roadside emergency.
I got the plus level with a few extra benefits that classic does not have.
But hopefully with the paycheck I get this, maybe I could get some work done.
I will have to wait and see..
Wish me luck..... It should be a pretty decent check this time.....
chevyCUCV
Massachusetts
Hi guys,
Isn't it nice when your CUCV doesnt need anything? I made it 6 months without any repairs, it was a pleasant surprise.
And the premium AAA is great for buying cars, i think the towing distance is 50 miles or something i have used it several times, just bring a plate to throw on whatever you are buying.
CycleJay
Marietta, Ga
ChevyCUCV,
Yes, I agree with you, mine has been running great for awhile now.
But just to let you know the AAA premium gets you more than 50 miles of towing.
You get at least 1 200 mile tow, and I think 3-4 100 mile tows..
Even with the AAA middle level you still get 100 mile tows..
But AAA premium gets you winching/extraction in case you need it, I believe.
I have a list of things I am going to do as preventative mainenence, as I can afford it though.
rbeasley66
Lakeland, Fl
Got the new heater core installed today with new hoses, put a shut off valve on the 5/8 hose so I won't share the heat inside the cab of the M1009. Waiting on the new aluminum radiator to get here so I can finish it up. Put new belts on it also, sure was a lot easier without the radiator in the way.
jeffhuey1n
SMSgt, USAF (Ret.)
1,664
Laramie County, Wyoming
A few days late for Aberdeen , but here is the new Winch PLATE and 10,000lb (off brand) winch.
Didnt turn out so bad I guess
Looks real good! I am not a welder, probably would burn the all metal barn down if I tried. Did you make the plate yourself or did someone else make it for you? I'd like to put a winch on the M1009 but didn't have an idea of how to do it till your picture was posted.
Jeff
