paraclete comes
- 5
- 18
- southern ca
The filter set up is the Racor 200 series head, comes with built in priming pump. Very nice set up and I would absolutely buy again. Heres a link to the item at west marine, they will price match so I found them online for $100.00 and they matched it, so if you can find one locally do that. But here it is: RACOR Filter at West MarinePara - what model #'s for the filter? What did you put under the insulation, looks black, Rhino? Are you leaving the guard black? I have tan on one side with black antenna and I like the look. Need to paint the other side and will probably go with tan also.
On the underside of the insulation I used two different types of paint. First I removed all the surface rust I could find then used Rustoleum cold galvanizing zinc rich primer paint as seen here: Amazon.com: Rust-Oleum 7585838 Professional Cold Galvanizing Compound Spray Paint, 20-Ounce: Home Improvement I found it at home depot or lowes I cant remember.
After that was all done I hit it with two coats of Rustoleum high performance enamel. Came out very nice and thick and excellent coverage. Its located here: RustOleum.com Also got this at Home Depot or Lowes, same stuff I hit my rims with and plan on hitting my roof rack with. I think I bought a case of this paint and absolutely love it.
As for the antenna, I like the CARC look myself too, I have some CARC on standby for the truck but am waiting to do the body work before that happens. So until then its black. Thinking four color desert or maybe the same scheme but with a od base, as seen at the mountain warfare training area.
