jets1959
- 9
- 18
- Lakewood, WA
Did mine last year but helped out a buddy and changed out his injector pump last night. It was leaking as fast as the main pump could send fuel to it.
Pabst?I thought it was a mount for my cooler to hold a 12 back of Pabst!!!
Don't knock the Pabst! My swill of choice! I one a blue ribbon once I heard.Pabst?
Pabst?!?!??!?
They still make that swill, uh, I mean, beer???
Thank you for the advice...Cyclejay, all of the bulbs come out from the back side of the cluster by turning the socket 1/4 turn. No need to pull the gauges. You should be able to get to all of them from under the dash. If you have broken pieces on your shift indicator you will need to replace them.
If you just did a mod, where are the photos? LOLDon't knock the Pabst! My swill of choice! I one a blue ribbon once I heard.
I just did a spin on fuel filter mod. Good, fun stuff.
I had a heckuva time finding the right size socket as I had one missing also. Apparently they come in 3/8", 1/2" and 5/8". Nobody around me carried the 5/8 sockets so i bought some off ebay, Dorman brand. If you need to replace your cluster anyway, chances are good that when you find one in a salvage yard you will also end up with sockets. And yes, you CAN pull the bulbs out internally after removing the speedometer and gas gauge, but that is doing it the hard way...All the other bulbs work though, except behind the fuel gauge, since the socket is missing.
Where do I find one?
Hello Twomorestrokes,I had a heckuva time finding the right size socket as I had one missing also. Apparently they come in 3/8", 1/2" and 5/8". Nobody around me carried the 5/8 sockets so i bought some off ebay, Dorman brand. If you need to replace your cluster anyway, chances are good that when you find one in a salvage yard you will also end up with sockets. And yes, you CAN pull the bulbs out internally after removing the speedometer and gas gauge, but that is doing it the hard way...
Hello Tom,Don't knock the Pabst! My swill of choice! I one a blue ribbon once I heard.
Hello Armor,....then went for a nice little ride in the country with my wife!![]()
I'm pretty sure it's a Dodge radiator overflow tank, from a Dodge CUCV. Notice the pentastar logo on the radiator....Hello Armor,
What is that tank for, that is on top and where the radiator fan shroud should be? With the warning label on it?.
You are correct, HoJoPo, I forgot to mention it's on a Dodge M882.I'm pretty sure it's a Dodge radiator overflow tank, from a Dodge CUCV. Notice the pentastar logo on the radiator....
