What have you done to your CUCV today/lately? - Part 1
gmjunky87
halifax, pa
Manuel Transmission vs automatic? Any thoughts? Anybody tried converting the 400 to any manual tranny?
Also this is the floor board of the M-1031 that I'm looking to buy. Is the 4wd shifter always in the manual tranny hole instead of the hole just to the left of the shifter? Any questions you might ask from this pic?
follow this guys build on diesel place http://www.dieselplace.com/forum/63...el-engine/431460-so-begins-my-cucv-m1008.html
dwbf fdwb
Hohenwald,TN.
On day 2 of ownership I had to replace the drive gear for the speedometer. went into town to a transmission shop and the man had one on the shelf and when I asked him how much it was he gave it to me. He told me that nobody has ever co039.jpgme to his shop asking for 400 parts. Granted it was a used part but fixed my problem!
SandBar
Full Time Patriot
763
245
GA/FL
I finally scored a 14b FF for my M1009. I won't be breaking it anytime soon! Lot's of details in my build thread:
Herewego
Yonkers/New York
oil pressure: I T'd off the idiot light sender by the firewall. Water Temp: I put the sender in the plug of the passenger side of the firewall. Tranny temp: Drivers side of tranny has a pressure port that the treads fit the sender. Let me know if anyone wants pics.
hunderliggur
Lothian, MD
We always want pics and part numbers if possible! Nice looking install.
chief1983
Saint Charles, MO
I could use a pic of the transmission one. I bought the threaded water jacket cover for the passenger side for water temp myself, and used the oil tap next to the overflow tank on the drivers side for oil pressure, but I was going to tap a new deep pan for my transmission sender since I wasn't aware of an existing place to tap for trans temperature.
Herewego
Yonkers/New York
Here you go. Its on the drivers side of the tranny......tranny.jpgtranny2.jpg
SandBar
Full Time Patriot
763
245
GA/FL
Well my RC lift u bolts do not fit the newly acquired 14b FF axle. I thought I was stuck mail ordering new ones, NOPE. I found a place in town that makes u bolts while you wait. Grade 8, case hardened with hardware for 50.00 in 15 minutes. Axle goes on tomorrow.
chief1983
Saint Charles, MO
Herewego:
Just looked and saw it for myself now. That's awesome. Do you know what the threading was that your unit s then? I'm guessing it's an NPT. I bought another Autometer Autogage 2355 to use as a transmission temp indicator, it comes with 1/8 NPT, 3/8 NPT and 1/2 NPT, hoping one of those works. I'm guessing that if it's detecting temperature there, the fluid level is that high in the transmission, and some is likely to run out when I pull that? I'm probably going to drop the pan and replace it with a deep finned pan anyway at the same time.
Herewego
Yonkers/New York
Herewego:
It is a 1/8 NPT thread. There is definitely fluid up that high up. I had to have some quick hands while laying on my back. I'm still not sure if its the best place to get a temp reading. But it sure is the easiest. Good luck!
truck1
10
San Anselmo,CA.
Just completed an AN/VRC12 install on my 1028. Decided to locate radios in the bed above the wheel well on a Hummvee tray. Used a MX 7777 behind drivers seat on the bulkhead. I like the RT 246 remote setup which allows complete control (10 presets and on /off plus hi / lo switch. Audio is also remote .Private Jarhead provided excellent equipment at a great price. Deal with confidence with Doug! Now Ham test and let the fun begin.
chief1983
Saint Charles, MO
Herewego, I was reading a long Pirate4x4 thread about the TH400 sending unit, apparently that's a pressure test port. They think there's not normally fluid flowing past that spot in park, so I'd keep that in mind when reading your gauge. It seems there's a lot of debate on the optimal spot being outlet line vs directly in the pan being 'best', but that test port wins hands down for being the easiest, and is probably sufficient. Some even install multiple sending units and a switch to toggle between which reading they get :p
