Russm
69
San Antonio, TX
Swollen and broken glow plug. Oh man. Its the a.c. delco 60g that everyone here seems to like. All the others came out fine. Had 3 different brands in there.
Trying the trick to pull out the end through the injector hole but ran out of daylight.
Sent from my LM-G710 using Tapatalk
cucvrus
10,505
Jonestown Pennsylvania
Be careful. I have been using curved jaw vise grips and needle nose pliers. One of my latest and so far greatest tricks is the wire tie thru the nozzle hole break off the tip/head and pull it out. good Luck.
Russm
69
San Antonio, TX
That's the plan.
cucvrus
10,505
By far the most frustrating thing so far!
Great Job. I knew you could get it done. No way is the wrong way. It is the way that gets it done that counts and that way may be wrong the next time. Been there done that. Never the same each time. End results the same. Resolution NOT every time. Have a Great Day. Good Job. Happy for you. No TM needed for that trick.
Russm
69
San Antonio, TX
You're so encouraging
rustystud
3,392
Woodinville, Washington
Thank you Jesus!
You got it out though ! That's the important thing. What you should do now if you drive your CUCV on a regular basis is to replace those glow plugs at a set mileage every time. Just like replacing spark plugs or changing the engine oil. That what most all fleets do. Just like you should do with your injectors.
Whitfield
Richmond Virginia
Installed all (3) new soft lines on the M1008 brakes. Bled & topped off with DOT 3. Questioning why the brake fluid looked so clean and new, I soon realized my mistake ~ Dot 3 + Dot 5 mixup. Suck all of the now maple syrup looking fluid out of MC and follow TB 43-0002-87 for BFS ~ Dot 5 Brake fluid silicone conversion. (3) containers of DOT 5 later we are once again clean and now purple at each bleeder.
Russm
69
San Antonio, TX
Wife is gonna drive it round the lot every so often. I'm about to leave for army stuff.
I've put a little less than 10k miles on it since getting it 5 years ago. What is a regular basis for glow plugs?
Going to seafoam in the fuel tank and call it good for now.
TechnoWeenie
1,803
Nova Laboratories, WA
Watched as some guy pulled out of a side street right in front of me.
**NSFW LANGUAGE WARNING**
You Tube
Code:
you tube O6t4fF5fKuE
They're probably gonna total it based on year alone.
Rain + no ABS + panic stop + no stopping distance = bang
Luckily he admitted fault to the cop and his insurance company....
One wheel is pointing slightly different than the other... brush guard got pushed into the bumper, which got pushed in.
It doesn't look that bad, except when you compare one side to the other, you can see how bad t was pushed in.
56608790_10218260783246206_2740001973058142208_n.jpg56431930_10218260769365859_1823729760551829504_n.jpg56697106_10218260768045826_150963208486649856_n.jpg56300185_10218260767285807_297974046333599744_n.jpg56549505_10218259593576465_1629331543505764352_n.jpg56276039_10218259593256457_1354188435216138240_n.jpg
rustystud
3,392
You Tube
Code:
View attachment 760314View attachment 760315View attachment 760316View attachment 760317View attachment 760318View attachment 760319
That is so easy to fix. Just a little pulling on the brush guard and a little touch-up paint on the fender ! Then probably replace a "tie-rod end" and an alignment and your golden !
Kaiser67M715
26
NH
You Tube
Code:
Fight it, there is probably minimal frame damage, a couple bumper brackets, maybe a bumper and grille guard, and it would be good to go. Lots of these trucks go for upwards of $5,000 now, so find a couple good examples in the same condition as yours, and the insurance will likely pay. It's a hard battle, but being to other driver admitted fault, it should be easier. Good luck.
Sent from my SM-S920L using Tapatalk
Michael
39
Fulton, MS
The insurance adjuster is probably going to want to total it, keep it and give you $1500 for it calling it an old wore out 80s model pickup. Just keep you guard up and if you keep it don't let them brand your title salvage. It might pay to act like your neck is hurting if they try to give you a hard time.
