1,827
My SECM has the Dodge M887 body. The heavy wisconsin genset was discarded long ago. Since it was engine driven, the box has an exhaust stack and ventilation from the bottom and top. Now there is a steel workbench on slides that comes out but at some point I'll like to put a Bobcat or Trailblaze in the back. Meanwhile, I've slept back there a few time on a stretcher and it was very doable, won't be if I add the welder.
kylethompson
30
13
Ventura, CA
Interesting use of a 1031. Guess if your feet get hot, you could open that door right there where they are. Same with your head for that matter.
If this thing had OD it’d be basically my dream vehicle. I don’t even care about the lack of power up hills.
But having space for ALL my camping and recovery equipment, water, wetsuits, fuel and food accessible from the outside is amazing for long camp trips. I’ve been inspired by this picture from a book on Baja since I was a kid. And this is pretty close to it!
Next I think is a lift of the roof and cabover sleeping zone for my son. He’s almost ready to graduate from Mexico “family trip” to “guys trip”.
Skinny
495
Portsmouth, NH
La Burrita...🤣🤣🤣
That is priceless!
I think long term I want to turn it into a crew cab and maybe a tuned up 4bt if the 6.2 ever goes. But then again I don't have kids yet and my other truck is a nine passenger Suburban. So pipe dream for now.
Sent from my Moto G (5) Plus using Tapatalk
kylethompson
30
13
Ventura, CA
La Burrita...
That is priceless!
I’m not a wrencher so forgive the dumb question... how are you going to turn the 1031 into a crew cab?
Skinny
495
Portsmouth, NH
Crew cab frame and cab. The rest is little details. Even a 2wd frame would work.
Curtisje
698
Okinawa, Japan
I began to replace my motor mounts today starting with the passenger side. I got it out by lifting the right side with a pry bar but that won't do the trick for installing the new one. And my wife is excellent at pointing out the obvious... "Why don't you use that cherry picker thingy you have in the garage?"
I'll finish the job tomorrow... with the cherry picker thingy.
Update: I would be done now if Autozone had sold me the correct motor mount. The struggle continues.
Update #2: Having read Cucvrus posts I went back to Autozone to get a motor mount fot a 1983 350. They brought out the same mount I already had. I asked Russ to humor me and bring out the other one they had on the shelf. It turned out to be correct. I should be up and running in a bit.
LT67
515
Bowdon, GA
The motor mount on my 86 m1008 turned out to be okay. All of the bolts holding it in place had all backed out🤣
Curtisje
698
Okinawa, Japan
I think I'll go with the duralast and save a few bucks. I'm not as convinced with the energy suspension parts or the other polyurethane parts makers.
Cucvrus I finally got to it. Thanks for all you post. Without your knowledge I would still be looking for the correct motor mount. Autozones computer gives you the wrong mount. As you have identified previously, tell them it's a 1983 truck with a 350 and you get the right one.
Skinny
495
Portsmouth, NH
Haha
I'm lucky, my girlfriend supports my habits but does say I'm cheating on her with my two mistresses at the shop.
Keith_J
1,328
Schertz TX
Ordered a 28MT starter from the usual scumbags, only because my 10% employee discount. Also ARP head stud kit and starter bolts. I have the bracket and keeping the 27MT as a spare.
LT67
515
Bowdon, GA
I wound up doing the same.... my 27MT kept eating up any bendix we threw in there
sgms18
85
North Augusta SC
Fixing a bunch of little electrical stuff. Replaced burnt out gauge bulbs w/leds. Fixed non working voltmeter. Adding autometer temp gauge. I'll probably look at my non working horn while I'm at it.
83k30
Jax, Fl
Well it's time for my annual maintenance on my daily driver M1008. Have a long list of things to do this time around. So far, I have done the rear main seal, oil pan, front timing cover, water pump, and cleaned up the alternators/pulley alignment. Still left to do is the front axle and suspension work, but I'm not in a major hurry so I'm painting most of the parts I take off.
