- 1,405
- 1,096
- 113
- State College, PA
Unfortunately, from what I have read, all of the vehicle records have been purged.If you have the time what can you tell me about NG1LNS?
But that number would most likely be on an Army vehicle.
How do the 1/2” belts work in the other pulleys?Holy schnikes!! I never knew they made a supercharger for the 6.2!
My upgrades pale in comparison....just some basic maintenance. I've been getting the CUCV ready to bring out of winter hibernation.
I had my dash apart to replace the CUCV voltmeter with VDO 24v & 12V voltmeters. I also replaced the heater controls with a new one from LMC since the old one looked pretty ratty. While everything was apart, I cleaned all of the contacts on the cluster circuit board, and I added LED's from NAPA for the gauge lighting and voltmeters. I thought it turned out pretty well.
Next, I installed new alternator pulleys so I can use 1/2" wide FleetRunner V-belts instead of the factory 3/8" belts. Hopefully these will hold up better and eliminate the famous 6.2 belt-squeal. So far, so good. They seem to be nice and quiet. The real test will be when I put some miles on them this summer.
So far, so good. I really haven't had a chance to drive it and put some miles on it just yet, but I have run the engine and it seems to be working just fine...and not one hint of belt squeal. Now they do stick out of the crank, water and PS pulleys just a slight bit, as they don't fit flush like originals, but only very small amount. If you look at my photos, you can get a idea of how they fit.How do the 1/2” belts work in the other pulleys?
.I installed a hard-to-find chemical detector m43a1 (I won it at an auction in Turkeyafter 3 years of searching) and a pioneer tool holder with tools
good looking truck… Interested to know the tire size and suspension setup
Toyo 315 75r16... a true 35in tall, 13in widegood looking truck… Interested to know the tire size and suspension setup
Remind me to never loan you my truck. You are tough on your rides.And, yesterday afternoon the transfer case fell off. After the pulley repair on the side of the road last weekend I made it another 80 miles on the highway and 65 miles off road through Canyonlands national park and a new problem developed.
I was cruising through the sand doing probably 35-40, came around a corner and there was a huge rut and then a rolling bump. Slammed the brakes, went over the bump and probably got a foot of air, and it turns out even with fancy Fox shocks my 1009 is not a trophy truck. The NP205 adapter split in half from the impact force and weight of the transfer case. The drive sleeve came off the transmission output and the case was sitting on the skid plate held in place by just the driveshafts.
I jammed it back into place with a bottle jack and a pry bar and ratchet strapped it around the crossmember to keep the case forward and the drive sleeve engaged on the transmission. Then I drove it 20 miles out mineral bottom road and to the highway to meet a tow truck.
I ordered a new adapter from Advanced Adapters in CA, which is being delivered tomorrow. Hopefully I can get it installed quickly and be back on the road.
There was no other damage, the suspension and steering seems to be totally fine, when I get it home next week I'll take it in to the alignment shop and see if the axle is bent at all but I think it should be fine. After almost 8 years and tons of miles the truck has never left me stranded, now it's twice in one week. Though I guess I am partly to blame![]()
Haha. I put this drivetrain in 8 years ago and it's been problem free. And the stock th400/208 was great before that.Remind me to never loan you my truck. You are tough on your rides.![]()
Is your last name McGyver?And, yesterday afternoon the transfer case fell off. After the pulley repair on the side of the road last weekend I made it another 80 miles on the highway and 65 miles off road through Canyonlands national park and a new problem developed.
