ridenby
- 18
- 18
- Frankfort,Ky
Wrapped water pump replacement up. What a screw ball pump design.
I am going to try to clean the wiring up and replace what I can while I am waiting for the starter to come back from the shop.
Wow!! Hope all is going to be ok with you. That other driver better hope he had good insurance! Take care of yourself in the hospital!rear ended.
40 min extrication.
4 fractured ribs, fractured l7 something or other...
Still in Hospital on o2 due to difficulty breathing due to pain
rear ended.
40 min extrication.
What battery size did you use? Wanting to do this myself.New heater core, new power steering pump, new harmonic balancer and seal, oil cooler lines, front and rear diff service, rear pinion seal, put both batteries on the rear tray with new terminals and cleaned up the old cable routing.View attachment 786598
rear ended.
40 min extrication.
Praying for you. Heal quickrear ended.
40 min extrication.
Not changing the way it's wired, just replacing some of the wires that have been spliced several times. The wire from the firewall to the starter has 4 splices in it!Get some new cables made at BestBoatWire. Fast service, not expensive, and great quality.
I'm wouldn't recommend re-inventing the wiring. Just replace the existing relay with a better quality relay. It only draws 9 amps, so any good quality automotive relay will do.
Some never have trouble with the starter relay. Some do.
Wishing you a speedy recovery.rear ended.
40 min extrication.
Do you know what hit you? Praying for speedy recovery!!rear ended.
40 min extrication.
a Comcast/xfinity truck/van according to the trooperDo you know what hit you? Praying for speedy recovery!!
rear ended.
40 min extrication.
