What have you done to your HMMWV today/lately
Daves86
82
Manassas/VA
DWF CDR Looks like this
The hose on the top goes to the sensor cup and (under the truck at the A pillar pass side) the smaller goes to the fording valve. sorry its not the best pic of the whole CDR.
Milcommoguy
2,431
Rosamond, CA
Adding shims. That's a first for me. I had to take out a bunch to get it right. Hows the bushing ? elongated holes ? bend up arms? ball joints ? frame tweeked ? saggy springs?
No two Humv are alike, I guess, CAMO
Not all of these BUT a lot pulled at all locations.
Lothar
701
North Arkansas
Theres a 3 inch body lift on this truck that really helped with access. Everything is in great shape and all bushings and ball joints are new. Wasn't planning on pulling the arm but just couldn't bust the bottom rear bolts without an impact. With the truck jacked up and another jack under the bottom ball joint, it was suprisingly easy to pull the arm out and pop back in. Would like to get my hands on some more shims as I think I may need more. Need a trip to the alignment rack next.
Daves86
82
Manassas/VA
So I took this to make that
Used that to bend this
That mounts onto my cup holder with homemade keymod
To allow my new Comms box be where I can adjust it as needed
This is the front two person, now I need to mount the rear panel and get the Fat 50 Storage mounts installed, Not sure where I want them yet, but it will come to me, or I'll just do it and fix it if I don't like it.
HoveringHMMWV
1,376
AL
Installed a fording exhaust since a snorkel was already in place. Not too difficult of a solo job if everything is kept loose during the install prior to tightening to spec. Replaced the thermal exhaust insulation for the tailpipe hanger since everything was disassembled as the original one was dry and cracked. That part arrived flat and needed to be bent into place which was a bear. Three of the four bolts were installed without too much trouble but that fourth needed to be reversed in order to complete. Also removed four of the eight glow plugs (passenger side) in preparation for their replacement's arrival.
Milcommoguy
2,431
Rosamond, CA
Good time to do a compression check...
Running solo here too, CAMO
