What have you done to your JEEP today
Bravo2Uniform
21
McMinnville, TN
As my Dad used to say....
It's been so hot here in Atlanta that I just haven't had the willpower to work on Murphy at all. That ends tonight. I'm doing something even if it's wrong! My Dad used to say that to me when I was a kid to get me moving during times of intransigence. Still works, too.
Another Ahab
4,942
Alexandria, VA
That lesson was drummed into me too as a construction project manager; when you got a project with a hundred or more tradesmen going full tilt, the last thing you ever want to do is say "Stop!"
Keep it moving.
Saberr
84
Temecula,Ca
I tore my engine down and took it to machine shop. Getting piston cylinders bored, and crank ground. Washed all my engine parts, put them on shelf. I then backed into shelf and knocked all my pistons onto ground, every head needs replacing now :(. Tomorrow i repair my steering wheel.
Another Ahab
4,942
Alexandria, VA
I tore my engine down and took it to machine shop. Getting piston cylinders bored, and crank ground. Washed all my engine parts, put them on shelf. I then backed into shelf and knocked all my pistons onto ground, every head needs replacing now . Tomorrow i repair my steering wheel.
You're not the first, so I sure hope you don't let it get to you.
Saberr
84
Temecula,Ca
No, i'm not. Its just irritating and an added expense. Fortuitously they not bad on expensive to replace. Also once the cylinders are bored, i may have needed a new piston size anyways.
Bravo2Uniform
21
McMinnville, TN
Back on the Project
Got myself motivated and back on the project. I was really timid about having to bend or re-bend my own vacuum lines...so I procrastinated.
Got the vacuum lines 80% installed - waiting on an oil line so I can re-install fuel / vacuum pump and complete vacuum system.
Installed propeller shafts, too.
I'm looking at a late October or early November finish if I can keep up the pace. My goal is to drive my son to school in the M38A1 on his birthday - Friday, 21 OCT 16.
Gotta stay motivated!
Another Ahab
4,942
Alexandria, VA
10-4 on that , Bravo2Uniform; it's the same with me. I will procrastinate and procrastinate and take on other easier projects, if there's a problem I got to deal with and I'm not sure how to tackle it.
Inevitably, once I get started it'll only be a small delay to getting up to speed and getting it done. But the thought of it will typically hold me up.
Goofy and silly of me, but I can tell you it always happens. :cookoo::shrugs:
Bravo2Uniform
21
McMinnville, TN
Are we related?
Bravo2Uniform
21
McMinnville, TN
Eyes! Bumper and pintle Hitch! Vacuum System! Gremlins!
I have been blessed with a productive streak and parts availability (thanks in large part to Matt @ QTM Parts).
The right and proper headlights were delivered and went in with only a modicum of fuss.
To the rear, I was able to attach the bumper and pintle hitch. I just don't have the skill yet to rivet, so until I do, I'm going with grade 8 bolts. Have had a time finding the correct bumperettes. No one has them! Finally found a pair on eBay and I snatched them up quickly. Still have one strap to put on the muffler.
I have all the vacuum system bent and ready to finish, just waiting on the long oil line. Finally found a 90[SUP]o[/SUP] fitting that was threaded correctly for the block and hose fitting.
The scary part is coming next - wiring up the 24V system. Have the harness and finally found the voltage regulator to harness cable - ready to take that hill next. I guess I'm scared because my last project was an M1009 CUCV and the electrical system was just infested with Gremlins.
Gralmk
53
Attleboro, MA
Went to the Jeep Jam in Blackstone MA Sat, post is late because my phone died! A nice 3 generartion photo!
