Somemedic
- 0
- 16
- Hobart, IN
I try to get a mobile1 filter, and a synth blend. It works wonders on cold starts
hmm wish had someone like you around my neck of the woods... or maybe i just haven't found that person yetyes it should be 7 qts. in it ive been in the army for 14 years working on 6.2 and now the 6.5 we always run 15w40 in them also. i have a 86 M1009 and i run 15w40 in it also
Uhm, I don't anymore. When I first had Big Ugly I was told about the horrors of ULSD and to run an once of ND30w oil for every gal of diesel put in. Then a few years later I was told that was hokey and stopped. Haven't noticed any difference other than less smoke, less cost, and Big Ugly runs slightly better.and what and when is time to add 'used oil' thru the fuel system on these engines? read a few threads here on that and am still not sure.......![]()
You can use any viscosity oil as long at it meets the needs for the temps you start and run in - as long as it has a SF/CD rating or better. In 1986, GM recommended as the "best choices" being straight 30W for temps 32F - 100 F. 15W-40 for 0 F to 60 F, and 10W-30 for temps minus 30F to 60F.15W-40 winter 30w in the summer. Anyone have the original sticker on their drivers side visor? The sticker gives info on starting a diesel, oil types, and 4wd use. Mine gives two choices for oil depending on temperature. cold 10w-30 - hot sae 30w. I guess my question is - Is 10w-30 really an option for the 6.2?
