Who's running dynamic tire balancing beads?
coachgeo
3,551
North of Cincy OH
I used these on the front wheels of my old mud truck and they worked. I was thinking about calling them to see what size would work on the LMTV https://www.centramatic.com/wheel-balance.rhtml?type=Heavy-Duty
side note.... one of the balancer companies like centramatic also makes a driveshaft balancer that works on similar principle!!! They make tire balancer's like centramatic too.
Lostchain
591
Portland, OR
what bead product did you use?
Magnum Balance Beads.
The place that sold me the tires provided them, I didn’t do any research, I just went with their suggestion. Probably would try the steel balls or just skip it altogether next time, I have a bad imbalance at high speeds so I don’t feel like the balance beads have helped at all.
Gunny 0369
Marine Gunnery Sergeant
294
663
North Carolina
Ned81
192
VA
I was all set to install the balance beads I bought( counteract brand) until seeing a bead found in the kneeling valve. I think the steel balls are interesting but I’d like to hear long term results. I’m thinking the centramatic would be cool if they make one that will fit. I had a washing machine that had the same type of balancing system. It worked great.
Ned81
192
VA
I called centramatic. They told me part number 800-820 should work $225 per axle. I’ll probably give them a try but need to save up first.
cdub0451
South Alabama
P/N 800-820 says they are for aluminum wheels only. I thought our wheels are made of steel?
Ned81
192
VA
steel.... there is aluminum's folk have put on that came off MRAP's
I called to place the order and spoke to someone different. He asked me for measurements and pictures and he determined they will not fit. This time I was talking to the fabricator. One main problem is the airline on the inside of the wheel does not leave enough room between it and the brake drum.
cdub0451
South Alabama
Dang... I was really hoping this would be a viable solution.
Bryteayes
140
San Angelo, TX
Do you know if anyone has used the driveshaft balancers on a FMTV?
hike
—realizing each day
939
Texas Hill Country
We are now running rubber Hutchinson beadlocks, 24 ounces, using 1/2" stainless bearings, dynamic balancing beads and 24 ounces, fish weights held on with extra split rim nuts opposite the CTIS wheel valves.IMG_4286.jpeg
[edit: added a photo of how we attacked the fish weights. @Gunny 0369 did it much nicer, we may redo them to match his method.]
It makes a noticable difference in the ride. Not as smooth as my wifes Grand Cherokee, but much nicer than before balancing—
Gunny 0369
294
663
North Carolina
We are now running rubber Hutchinson beadlocks, 24 ounces, using 1/2" stainless bearings, dynamic balancing beads and 24 ounces, fish weights held on with extra split rim nuts opposite the CTIS wheel valves.View attachment 927371
I have 3200 miles on my set,
Same results and no issues to report.
Gunny
Bryteayes
140
San Angelo, TX
Where did you get the Hutchinson beadlocks?
