Rangerpig
- 0
- 0
- Upstate, New York
Doghead, origional problem was top right fuse (circled in blue) was popping when lights turned on. I put new fuses and next issue was both red and blue (pictured) melted.Does your horn function properly?
Just for fun, try removing your 15 amp horn fuse and see if your 30 amp fuse still melts with your lights on.(I have a theory)
If you think you did not solve the loose fuse connection, maybe you could solder in wires and use a new external(out of the fuse box) fuse . I'm thinking about using a 30 amp inline fuse holder, with the wires soldered into the original fuse terminals/sockets.
Also, you could try measuring the resistance in all the headlight wires to see if you have a bad one.
I took out 15amp horn and although neither melted, the top one (blue), popped....
I see talk about relay mod, but neither money, nor skill will allow me to do that right now. Fkn a.
Sent from my SM-G935V using Tapatalk
