rustystud
- 3,229
- 113
- Woodinville, Washington
Here's my truck with my new Warn 36,000 Ibs Snatch Blocks. I took them both apart and cleaned up some rust and repainted them. The factory didn't paint the insides. I also drilled out the bottom support bolt for a 3/8" grade 8 bolt. They had a 5/16" bolt there. You can also see Warn uses a roller bearing in their blocks, and the housings are cast-steel.
Now I just need to get some more 3/8" "100" chain, and I'm set. I could go with some 1/2" "70" chain but I don't want the extra weight.
