WOO HOO! Original Genset filters available that fit
Speddmon
Blind squirrel rehabiltator
30
Cambridge, Ohio
the fuel pumps just have a screen on them that is removable and very easily cleaned. If you absolutely need to replace them, I would try a Facet pump dealer for parts.
joewright313
Hanover, MD
Can sleep at night now
Thanks man thats helps alot i been pulling out my hair for weeks trying to find the right filters i just have one question it has three fuel filters doe the first can all the way too the left take a filter
WARWAG
All of the filters are readily available and easy to get. You can even purchase them online and they will ship them to you. My signature lists all of the filters. As far as the first fuel filter housing (on left of the 3) that is a screen filter just needs to be cleaned. All three of mine (purchased 3 gens) were just serviced by the Military so they were extremely clean. The other two are the fuel filters that are listed below. To remove the cans they sit in you need to look at the top of them. The bolt holding them is on top. The first fuel can (on left) is held on the bottom with a bolt. Change all of your filters and oil before starting her. Also flush your fuel tank. Good luck
leedawg
11
Napa / CA
Just wanted to say thanks again to the OP. I just talked to Paul he knew exactly what I was wanting stocks tons of these just for us he said. So I ordered 6 of each any way great find and im glad I can keep the whole unit stock not that spedmans spin on filter adapter is bad looks great I might go that route still but for now glad to have found the original parts.
Thanks again.
LuckyDog
11
Freedom, NH
Just finished researching the Facet Pump filter/screen.
The TM -24P has the wrong part number.
The correct part number is: 479729
Googling "Facet 479729" brought up several hits and the pictures matched the filter in my pumps.
Some sites sell the filter with a new gasket as a set. (<$6 before shipping)
Just bought my filters from RaceMart!!!
Today's prices:
Fuel Filter: Fram C1125PL $5.87
Oil Filter: Fram CH6PL $4.49
Air Filter: Fram CAK253 $15.61
I bought enough that the shipping only added $1.15 to each filter.:jumpin:
Total was over $80 :eek:
Wildchild467
58
Milford / Michigan
I was reading threads about the napa 3113 filters having the tabs bent down in order to work... has anybody looked at the Napa 3511 filter? i think its the same as the deuce primary. i did a search and nothing came up for it.
the specs are:
Part Number:33113UPC Number:765809331136Principal Application:Allis-Chalmers, Case, Clark, Continental, Waukesha (10 Micron)</B>All ApplicationsStyle:Cartridge Fuel Metal Canister FilterService:FuelMedia:PaperHeight:3.750Outer Diameter:3.092Inner Diameter:1.095Nominal Micron Rating:10
Gasket DiametersNumberO.D.I.D.Thk.15131 3.587 3.317 0.125
and.....
Part Number:33511UPC Number:765809335110Principal Application:Detroit Diesel Engines Secondary (10 Micron)</B>All ApplicationsStyle:Cartridge Fuel Metal Canister FilterService:FuelMedia:PaperHeight:3.622Outer Diameter:2.903Inner Diameter:1.085Nominal Micron Rating:10
Gasket DiametersNumberO.D.I.D.Thk.15095 4.031 3.468 0.093 15133 3.663 3.437 0.125 Packed 0.750 0.509 0.047 Packed 0.750 0.454 0.046
the sizes are just a little different, but the 3511 does not have the tangs. ofcourse the gaskets are a little different. just food for thought since my advance auto said they couldnt get the Fram filters even though they sell Framaua
Wildchild467
58
Milford / Michigan
wow, those specs did not copy and paste well at all... sorry guys. if you go to wix filters and look up the napa filters, it will take you right to the specs.
