- 4,640
- 32
- 38
- Cambridge, Ohio
the fuel pumps just have a screen on them that is removable and very easily cleaned. If you absolutely need to replace them, I would try a Facet pump dealer for parts.
All of the filters are readily available and easy to get. You can even purchase them online and they will ship them to you. My signature lists all of the filters. As far as the first fuel filter housing (on left of the 3) that is a screen filter just needs to be cleaned. All three of mine (purchased 3 gens) were just serviced by the Military so they were extremely clean. The other two are the fuel filters that are listed below. To remove the cans they sit in you need to look at the top of them. The bolt holding them is on top. The first fuel can (on left) is held on the bottom with a bolt. Change all of your filters and oil before starting her. Also flush your fuel tank. Good luckThanks man thats helps alot i been pulling out my hair for weeks trying to find the right filters i just have one question it has three fuel filters doe the first can all the way too the left take a filter
Carburetors for the MEP-003A?If anyone is looking for air filters for the Mep 003 I have a whole bunch, also have NOS carburetors and fuel pumps.
Yes, exactly the same. In fact the ONLY diffrence is the MEP003 has 4 cylinders compared to the MEP002 has 2 cylinders. The generator side is the exact same.That sounds great! I have an MEP-003A and I wonder if they are the same? I'll try to find out.
Just finished researching the Facet Pump filter/screen.the fuel pumps just have a screen on them that is removable and very easily cleaned. If you absolutely need to replace them, I would try a Facet pump dealer for parts.
