Another Ahab
- 4,864
- 113
- Alexandria, VA
Love the M 60. Will you need a different MG mount than the one you had on it? By the way, loved the walk around video!Finally something to be cheerful about. My Airsoft VN M60 showed up today.
No that is the correct mount. There is a minor modification for the airsoft (compared with an actual one) on the mounting pin but everything else fits.Love the M 60. Will you need a different MG mount than the one you had on it? By the way, loved the walk around video!
The core might work but the inlet and outlet pipes are in different locations. I haven't heard from Keith so I'm just going to start pulling it tonight and see if I can get it to a radiator shop before the weekend.I know this is a long shot, but will a deuce radiator work on a gamma goat?
If so, you can have my parts truck radiator.
Actually the rust is on the deck of my M116 trailer. I took the old belts outside in the light for the picture. Unless you were talking about the radiator and in that case there is some minor surface rust on the bottom but it's very light and the junk on the fins is leaves.That is some great shots ....Lost of rust also I see..
The belts on mine were so dry rotted that they just pulled off in pieces. Mark, they are a standard size 3/8 x 35(water pump) v-belt a very common size, you should be able to get them locally very easy. A common part number is 3L-350. The longer fan belts(1/2x67) are 4L670.
These are the ones Mark gave me and they seem to fit perfectly. If you're not in a hurry the water pump belts are $9 for both from MuttParts and $10 each from NAPA.Sorry to hear about your troubles, I would think if the head had warped you would have coolant in your oil, if not I bet you are good to go. Do you have the numbers for those belts?
And if you will never take it swimming, you could use the iron without difficulty.Yes they are pretty common, seen several in boats, big difference is the military 353's had an aluminum block versus iron for civy applacations
