mudguppy
- 15
- 0
- duncan, sc
J's correct - i just did a removal and the driveshaft can stay.Yeah jwaller but I want to make sure the front driveshaft dosen't interfere with the removal ...
also, you don't have to unbolt the winch drive shaft - just let it pull out of the slip yoke. then pull/replace the PTO with flange and yoke assy still attched to the PTO flange. re-align during final transmission alignment. or, take it off once on the ground and reinstall once trans/PTO is back in.
