3dAngus
- 101
- 63
- Perry, Ga.
Fire extinguisher standing by...
This ties directly into the main fuel injector line, and is located over the top of the turbo unit. It is leaking down on the turbo and burning off, so I'm grounded. Tech manuals show something like it, but it is a different mount. It has two lines in/out, and is leaking down at the bottom of what looks like a pipe opening, which is normally open without a pipe intended. Did a search and found something like it in the tech manual under intake manifold but the mounting is completely different.
Questions:
What is it?
What does it do (ie function)
Is it repairable?
Should I just replace it?
Source for a new one recommendation?
Questions:
What is it?
Is it repairable?
