I've got the snap ring out and I've not only tapped it on some wood, I've fully wound up and HEAVED it at a piece of 2x4 on the workbench and I can't get that metal cap to pop out.After you take the snap ring out you have to take the heater and tap it on some wood, its a tight fit. It will come out of there.
Did you get your flame nozzle yet? I'm thinking of buying one from SECO as well, wonder if you had good luck.The new manifold heater at SECO is $98.45. Credit cards accepted.
I pulled the clip out as stated above, tried to pull the rest of it apart, and it didn't seem to want to work with me. I got it covered. Thanks.
Mine was not easy. One thing that I noticed, when "rapping" the valve body, I was rapping the end with the bore that the snap ring fits into on my workbench. After a lot of "firm" knocks, I noticed that either me or someone else had deformed the end of the valve by pounding that end. The bore that the guts slide into was getting really beat up. Then, after taking the spray nozzle end out, I put a rag over the snap ring end, a pipe plug in the "in" port, my thumb over the spray opening, and compressed air into the "out" port, and it blew the cap, ring etc out. I would highly recommend slight doses of air, I was able to contain everything with the rag. Might even be able to do it with the nozzle in place, as the hole is very tiny. I wonder how many of these have been wrecked by pounding the end, it's only cast aluminum.I still haven't been able to get mine apart.
Here's what mine looked like. I had already taken the nozzle tip apart and reassembled, didn't get pics. By the way, the small "O" ring on the brass piece is a square cut ring. I ordered some from McMaster Carr, Square Buna-N "O"-ring, size 010.Add me to the list I have to do this same repair. Any got photos of the guts?
These pics were posted on an older thread. What I see different in these than mine is there must still be a piece inside the body......and my spray nozzle only had a small ball and a small spring, instead of the three pieces on the penny in the pic. I hope the darn thing works and doesn't leak when I'm done!Add me to the list I have to do this same repair. Any got photos of the guts?
