Cucvnut
- 56
- 48
- Carver, Oregon
what about a spartan locker?
You could always donate one for him to try .what about a spartan locker?
I would use the Detroit Locker that is alreadt sitting there and no cost involved.So can you.
And don't forget.... The more complex you make your system, the more parts there are to fail. Especially when your working the system.. The cables, actuators, levers and brackets are not needed with locking hubs and it will always be there when you need it.I would use the Detriot if you've already got it. Snow and icey roads seem to be everybody's big complaint with a front locker. I've ran front lockers in several of my rigs and in the snow and ice I just lock in one hub for normal driving (3 wheel drive) around where I have to make turns like city streets. If I get to a place where the snow is deep, drifts etc, I just lock the other hub in giving me full 4WD. Its kinda a pain getting in and out in some spots to keep locking it in and out but it beats the **** outta the price of a selectable!
Didn't think about that option, be kinda handy if ya bust off a front wheel or something.Detroit locker!!! Much simpler, its heavy duty, no special fluid needed!!! If turning is an issue or sliding all over the road, just unlock one hub.....whaaaallaaaa!
So what size pipe do you suggest I run on an engine with 370hp injectors, a #5 fuel plate and a turbo pushing 32-35 lbs of boost?All this cause you want to run a 4 inch pipe? you dont want to spend money on it but you want to run a 4inch pipe on a truck that does not need it. if it means that much to you to have a 4 inch pipe and you dont want to spend money on it becuse of other priorities, then you best run it out the side of the fender and up the A piller of the cab. I have done some strange things but to step over a dollar for a penny is just not right. The best locker running is the detroit. If you use anything else you will not be happy and i say this cause the exhast is bugging you that bad, i know a track lock will drive you nuts!
I definatly dont wheel that hard !!!!! lolDidn't think about that option, be kinda handy if ya bust off a front wheel or something.
