CycleJay
- 7
- 0
- Marietta, Ga
Just got the speedometer repaired. Now it works...
That is all for now...
Do you reckon that could hold the eight of two spares just fine?I used lock washers and lock nuts, siliconed under the foot and thats about it. Might go to a friends house and tack the joints with a welder but I don't think it is needed.
Tim
L U C K Y!!!!QUESTION: What have you done to your CUCV today/lately?
ANSWER: Not a freaking thing.
To day I installed a new rear window regulator in my Blazer. The handle finally gave out and would not roll the tailgate window up or down. I thought it was the clutch at first; but it was the tiny crank gear between the two large elevator gears.
While I was in there I cleaned out the mud built up in the bottom of the door, soaked the latches and added new foam donuts to the rods. There was no felt in the channel guides, so I replaced it with some hunter orange felt I had. Also installed new top/cap channel guides and inner and outer sweeps.
OOOPS! Almost forgot... Washed the interior of the endgate and installed fatmat (lowes roof flashing) to quiet the gate down.
This tailgate overhaul was thorough; but not as difficult or hard to understand as I thought it would be. The gate feels and sounds more solid/quiet. The window cranks up and down smoothly and the clutch was just fine; showing only acceptable wear.
If your endgate window is taking a lot to crank up or down I highly recommend this overhaul. Good one day project.
The regulator was about $135 shipped. Comes with new rollers and is easy to install. It is an ACDELCO part 15641780. Shop the web by part number and look for free shipping.
Your window troubles may not be the clutch, mine wasn't. Besides the overhaul with new parts means your existing OEM clutch- hard to find, will last longer not working so hard and wearing so fast.
NOTE. The middle adjustment screw of the latch control is a LEFT thread screw- don't shear this turning it the wrong way.
