Death of a Multifuel
980
24
Dover, New Hampshire
Made some progress on this job today.
Started out early with coffee and donuts, had a lifelong buddy over for the help and company. We started by first dropping a side of the bed and turning it into our workbench. We drained the remaining oil and coolant from the block and radiator, saved the coolant for the break in of the new engine.
Next we removed the air cleaner and all of the plumbing, the heater and hoses were next. Made sure that we noted all hardware and connecting points with some dilligent note taking and photography.
The radiator came next, not terribly difficult but did need to remove the fan for clearance and pull it out with the radiator.
Disconnected the tach cable, air line and regulator line.
Next pulled the exhaust flex pipe from the back of the trubo.
Disconnected electrical leads to manifold heater, oil pressure sender, starter relay, starter and generator.
Removed the relay from the block.
Disconnected ground straps, fuel line, fuel return line, engine stop cable and throttle linkage.
Just started on the transmission, pulled the shifter and floor panels. Next week I'll be dropping the trans and unbolting the engine mounts. I have a front end loader lined up that will be pulling the motor, it should lift it high enough that I will not need to remove turbo or generator.
I put the grill and side panels back on for the time being so I could close the hood and shield everything from the elements.
Thanks to my friend I have six pages of notes regarding hardware, parts and disassembly proceedures. Plenty of pics too.
spring 2013 005.jpg.spring 2013 010.jpgspring 2013 013.jpgspring 2013 012.jpgspring 2013 011.jpgspring 2013 022.jpgspring 2013 031.jpgspring 2013 032.jpg
SEAFIRE
Seadrift Texas
Good Luck,
we went through this in 2010: http://www.steelsoldiers.com/showthread.php?60305-Engine-swap-fun
On a side note, one of our mechanics used to work for a dredging company, he said once he was called to a tug boat that had an "engine noise", in the engine room he found the engine running with a hole in the block with a connecting rod going back and forth. He killed the engine, removed the rod, patched the hole, the engine ran until it got back to dock.
3rdaavbn
Suwanee/Georgia
Yep, It is all about how somthing is rated by the military. 2600 rpm redline. 10,000 lbs winch, All of it based on the very minimum proformance required.
Carlo
20
palazzago italia
Ever since I read this I baby my M35A2 more than ever. I flushed out the radiator this weekend. I have never ran the rpms over 1900. I just cant bring my self to pushing it this hard.
vtdeucedriver
Vermont
Can anyone point me to where I might find the torque specs for:
A. Valve cover bolts
B. Pressure plate bolts
C. Turbocharger mounting nuts
Thought I had a LDT manual. All I have is for the LDS.
Valve cover bolts...............36-60 in lbs
Pressure plates...............115-120 Ft lbs
For the install of the turbo, I did not see a torque listed as all the book says in install in reverse order for removal...............HA.
Now again this is for the LDS and the book is dated SEPT 1964 so things might have changed.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
While I can understand that number is in the TM, the valve cover torque is awe-full high! I would just snug them down. That style gasket doesn't take much torque to seal well.
DieselBob
13
Arnold Maryland
From the Continental Aviation and Engineering Corporation manual for the LDS-456-1A, 1968
Turocharger to exhaust manifold bolts: 23 to 27 lb/ft.
980
24
So made some more progress today, removed the starter and took apart the turbo.
I also dropped the trans, I removed the tailshaft, clutch, and pto linkages yesterday.
The transmission removal proceedure that I used is outlined in the following thread http://www.steelsoldiers.com/showthread.php?60303-Yet-another-transmission-replacement-thread! This time however, the removal went much smoother.
I pulled the engine mounting bolts and bushings as well, so it's ready to come out as soon as I have the time and a tractor.
-GM
24
Quick question for anyone who knows.
My new multi has the red paint on the flywheel face and the pressure plate disc, do I need to remove that paint completely before I install the clutch or is it ok to leave it on? I have heard conflicting opinions.
-GM
Vintage iron
15
Falmouth Ma.
The paint is to protect the flywheel surface from rust during storage. Sand it off the flywheel face using a orbital sander with 220 sand paper. Make sure to keep the sander flat and finish the cleaning with Lacquer thinner.
