I have one of these (well the VMPA does and I maintain it) Plenty of expensive parts, but then I don't break it that often. REALLY useful to lift things onto trailers, around the yard, the turret of the Sherman, an M60 Tank engine, overhead beams for my garage, etc. Who cares about towing a vehicle, let a modern rollback take care of that, insure it for $50 a year. it's great for displays as no one see's them around (at a local show we hung an M151 up in the air to transfer it to a truck for hauling away one year, and a mule for maintenance another year)
The cab bows are the same on the Deuce, plenty out there, expect to pay around $250 for a soft cab top cover or more.
Yes, if a hose blows under load it can get messy, I had one give out and it cost $60 to have it made.
We used it to tow the local museum's T-97 SP gun show in a video here:
https://www.youtube.com/watch?v=4RmkmKYBKYg
Advice? Drain the fuel tank, there will likely be a ton of water in it from condensation, then bleed the fuel and have someone standing by to cover the air intake in case your injector pump is rusted in full throttle position. If it starts, it will crawl really slow taking forever to get past 30mph, and on a 3 mile stretch you might hit 55mph (likely less) It does run faster after it warms up though, so give some thought to warming the beast up 1st.
Otriggers are there for a reason, use them, but be advised nothing is automatic, they are ARMSTRONG outriggers and I tend to be lazy using the crane off the back in a direct fashion VS. the side whenever possible. Rear winch 40K, front 20K, with double wire pulley youcould lift 20K, would need a wiffle tree if lifting a Deuce for towing, if not the hook will crease the hood on the towed vehicle and possibly the radiator...
I have fun with it, took a gallon of paint to change it from Fire Engine purple (faded red) to 1968 Green. The one your looking at was likley from the late 60's to early 70's as well, they stayed in service until the 90's. Manuals are available on-line, don';t confuse them withthe M800 series which has the same rear bed but totally different dash layout, engine. Bearings for the wheels set me back about $80 per bearing from memory, they are huge and expensive, ours must have sat in a pool of water for a long while to rust as bad as they did, but a little heavy lifting and elbow grease and we were up and running.
Enjoy it. Value unrestored: 5K, running:8-12K dreaming of a business sale, 15K+ The Littlefield auction had two wereckers go for sale last weekend and they went for around 8K from memory and status was unknown as far as running.
The 5 Ton engine has a different turbo, possibly different set of pistons and possibly a different injector pump but it's the baisc Deuce multi-fuel engine which is why she lacks speed with all that extra weight (22K?) on her.
V/R W Winget
Vid of transfer in the rain:
https://www.youtube.com/watch?v=fjoVysJRKxA
