Oil seal mod. for 3053 input shaft
M35A2-AZ
436
Tonopah, AZ
If these retainers really got that scarce, and before spending a fortune for a new, OEM part... what about a home-made, upgraded version of the same- this one WITH oil seal?:wink:
G.
Nice job, I was just thinking about an oil seal. Have you used the one you did?
Has it worked for you?
Did you make a new one or mod. the old one?
rustystud
3,392
Woodinville, Washington
G.
How much would you ask for one ? I would really be interested !
It's interesting that you have posted this now. I took one off of one of my transmissions last week to send to the machine shop to see if they could install a oil seal some how. They said the same thing about not enough material to safely cut out for a seal.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
I had already posted some about this modification in another thread but then decided to better start a new one...
Above are some of the posts about this same subject, moved over from that other thread.
Fact is, the old design, 7/8 inch-long, RH-threaded/grooved section inside our front bearing retainer really does its job, keeping the oil inside the cavity - provided there is no wear at all, and everything stayed free of sludge, grease, etc.
But... there must be a reason for modern, manual transmissions to have an oil seal there, instead...?
So the idea behind this was, why not try upgrading our old Spicer's to run an oil seal, thus eliminating one more (possible)problem area?
Well, it is doable, but a new retainer has to be made. The stock one simply has not enough material there, for such a modification.
Pics, below...
Drawing and more details available.
This is still in its experimental phase and so far only a pair of prototypes were done here, with only one of them "highway-tested" and OK.
Hopefully someone in this group, with a machine shop- and located in the USA, could make a short batch and then find some "guinea pigs" to run these for a while and have some feedback?
G.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
No problem, Sir!:smile:
And I really thought about you when I said "guinea pig"... because I know too well how many miles you drive!
Just let me update that drawing, so it has all the measurements- and in inches if you prefer?
G.
Jeepsinker
470
Dry Creek, Louisiana
Inches would be better, but metric is useful as well. I will be bringing the drawin to a local CNC machining facility to get at least one made and see how it works.
Section8
Little Fort, B.C., Canada
Send me a deuce and I will see about getting one made and put it through some heavy use. Both highway and off road use. Loaded and unloaded. Have a ranch which needs lots of land cleared plus my job is a half hour drive away every day at 100km an hour speeds or 60mph for you Americans.
Could probably get you some good real use data that would be comparable to what the military would put the rigs through.
Just give me a deuce! I don't care how old or beat up. Just as long as she runs so I can get the modification made and test it.:p
rustystud
3,392
Actually I think Peashooter (Aaron) would be a better fit for this project since he does his own machining (excellent work !) and we would not be paying a third party for the parts. Just my 2 cents.
Jeepsinker
470
Rusty, Gerhard and I have already come to an agreement. Now, the idea and credit belong solely to Gerhard, so if he chooses to share it with Aaron I have no problem with that. All I ask is that you guys give me a chance to see what I can come up with and what it costs. Like I said, it is being done at a CNC house, so there is little room for error and less man hours involved. Everyone's time is worth something.
peashooter
210
Hanover, minnesota
No problem, I didn't realize it was already in the works. I would have only been able to make a couple for people to test anyway, so we would have still needed to find a shop to make them in ongoing quantities if it works out. Glad your on it Garrett. Thanks
rustystud
3,392
Your right, I didn't think about how many miles you put on the deuce either. Which makes your rig a better test subject.
peashooter
210
Hanover, minnesota
Any news on this sucker? Jeepsinker, have you been able to get a quoted price from the machine shop yet on making these or had a chance to have one made and installed in your truck yet?
