Atl. bracket question need advise..broke
hummer4x4guy
Lansing, Mi
OK, I have a 60 amp alternator and the POS aluminum bracket has broke in the back where the bolt allows the power steering pump to be adjusted.
So I want to replace it with a steel one but I am not sure if parts listed for the 100 amp alt will also fit mine.
Or if anyone knows of the proper part # for a steel alt. bracket that would help also. Tho I believe the part # should be: 12338786
hummer4x4guy
Lansing, Mi
So what's the special tool used to get the pully off the PS pump? Need to replace that bracket also as one of the holes is much larger than normal. I assume a standard 2 jaw puller to remove but what is the trick to reinstalling it?
86humv
541
Texas
Make sure you have a rear Alt. bracket or things happen to the aluminum one.
hummer4x4guy
Lansing, Mi
Yeah I didn't have that bracket before but I do have it now. Tho the holes seem to be drilled in the wrong place. As if they were too far apart. But someone mentioned that it will fit ya just gotta do both sides at the same time or something like that.
hummer4x4guy
Lansing, Mi
Could ya post a few photos? I have the bracket on order already and will attempt to bolt up that rear support bracket and pray it fixes the problem.
NDT
7,293
Camp Wood/LC, TX
Got a part number?
No. My 1992 dated invoice for the part says "100 amp steel bracket $97.00" But my 1985 dated TMs show the same (aluminum) bracket being used for both the 60 and 100 amp generator. So the steel one should retrograde, unless I am full of crap.
hummer4x4guy
Lansing, Mi
OK. I have seen "100 amp steel brackets" but I've already got an aluminum one on order and when I hookup the rear support bracket hope this will let this one stay around for a good while.
glassk
Hampton, GA
TM9-2320-280-24P
has the bracket for 100 amp , part target shows it's a cast iron one, hummer guy parts shows it fits 60/100 amp, you might need to look for kits or parts from one the kit has been installed
http://www.parttarget.com/5340-01-448-4245_5340014484245_12342036.html
http://www.hummerpartsguy.com/BRACKET-ALTERNATOR-60-100-AMP_p_18918.html
13 PAOZZ 5340014484245 19207 12342036 BRACKET,MOUNTING PART OF KIT P/N 1
57K3519.............................
Figure 472. 100 AMP Dual Voltage Alternator and Regulator Mounting Hardware Kit
