You are spot on.You most likely bought a NTC HMMWV, rode hard put away wet. miles of washboard roads at Fort Irwin.
ha I actually did that. Full of sand!!Take out your air cleaner, and drop it on the ground or roll it down the driveway. I bet you it's like smoke screen.
Why would you care? They are both fairly lousy diesel engines, but replacements are plentiful and cheap. Power wise the 6.5 is only marginally better and with an aftermarket turbo and injector pump the 6.2 makes more power than the 6.5.One thing I am concerned with is it listing a 6.5 engine and it actually having a 6.2.
I am not sure I can comprehend exactly what you are describing?Could you tell me on any of your hmmwv's if the firewall flex is normal with the gas pedal operation?
am I missing something? Whats the "real damage?" A dent in the oil pan,dirt, surface rust? If I had a dime for every HMMWV that has a dent in the oil pan, I could retire. You clearly have not seen the trucks from the 99 auctions.The only picture they show that is under the truck neglects to show this. Whoever took that GP picture saw that, and decided to not represent the product.
Integrity?!![]()
Not to hijack this thread But will GP allow you to inspect before bidding
did you open a claim for your "iron clad guarentee"?. I know folks who have used it, they have in fact had very good outcomes.My recent 1990 M998 purchase.
In the auction info it stated truck cranked but would not run. So I figured I'd gamble as all my 1008s and 1009s needed only battery's or glow plugs to start.
Get the thing home. No coolant, I assume it was drained for storage, so I put in 5gal. Put in fresh battery's and sure enough it cranks but no start. Check glow plugs; all 8 are swollen, cracked, or missing chunks. So I buy a new set on ebay. Couple days later I install them. After a few tries it actually fires up. But........ Instantly it blows most all of the coolant out, and there is constant white haze surrounding the truck. Hahaha. Headgasket or crack somewhere I can only assume.
I gambled and didn't exactly win this go around. For my $5250 winning bid Ill accept it. Just looks like my 6bt swap must happen sooner rather than later.![]()
Nah, I figure it said cranks but doesn't run so I get what I get. Which is perfectly fine. I had one dent in the back where it looks like someone hit something while the antenna mount was attached that wasn't mentioned or pictured but I figure a 2x4 and mallet will straighten that just fine. Over all I think its in good used shape for what it is and I'll live. Guys at the storage lot were very helpful (Plainfield IL). Pushed it up on the trailer for me and everything.did you open a claim for your "iron clad guarentee"?. I know folks who have used it, they have in fact had very good outcomes.
here is the problem as GP, they are a get it to run at all costs...running makes for higher opening bid, 7500.00 as compared to 5k. I am seeing cheap store bought batteries in some of these lower quality trucks, meaning they tinkered with them to get them running...batteries, bad jump starts, starting fluids....all of this equals blown EESS boxes, swollen glow plugs and effed up motors for using starting fluid...NEVER use starting fluids on 6.2,6.5 and 6.5TD's.
The real damage is that it was purposely not disclosed... I feel in a way to draw up more bids then what it would go for compared if a honest listing was portrayed. Legal definition is fraud. But, hey I'm just some pog SOB who blew a wad of cash right?Am I missing something? Whats the "real damage?"
Good luck with that.I figure a 2x4 and mallet will straighten that just fine.
