Deuce Wrecker Engine Swap
UPFINN
Ishpeming Michigan
Very good thread!
Was considering getting what looks to be a 1966 M35A1 or M44 with most likely a REO/White OA331 gas engine. Truck is in perfect shape and I am looking into the possiblity of an engine swap.
Is the OA331 compatible with with the 5 speed spicer transmission and rockwell transfer case? Looks like I could just drop a multifuel engine right in, just changing the mounts, re routing the exhaust to a stack, changing fuel tanks, and guage/control linkages in cab? I am no expert in engine swaps by any means. I can get the 465 turbo engine for around $1500. Wondering if this is more trouble than it is worth to get a M35A2 work truck.
This thread has helped me get an idea of what to expect. Got tired just reading it!
1,127
Engine is compatible but gasser doesn't have an overdrive transmission, since it revs higher. Slower revving multi will require a 3053 OD trans to maintain normal (normal for a deuce) speed.
I have the correct front crossmember (mount) and rear engine mount for multi (crossmember is M44A2 style, the later multifuel crossmember).
Rest of what you said sounds right.
SETOYOTA
441
georgia
Well planning on the swap with my M108. Finally got a good donor truck. Is the front cross member that needs to be changed the same on winch and non winch truck?
1,127
Yes.
gunboy1656
22
Beaver Falls, PA
Kid had phone.
Well, today my goal was to get the replacement engine painted and ready for the future install. Also wanted to get the multifuel front crossmember sandblsted and painted. Well, got all that done and it was just after lunch so I started the engine removal process. Attached are a few pics of what I got done today.
SETOYOTA
441
georgia
Finally made a little progress. The old motor is ready to come out. All disconnected but it got dark before we could remove it. My plan is to go ahead and remove the cab as well.
