gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 785
- 113
- Cincy Ohio
Bump for JJ
Engine is compatible but gasser doesn't have an overdrive transmission, since it revs higher. Slower revving multi will require a 3053 OD trans to maintain normal (normal for a deuce) speed.Is the OA331 compatible with with the 5 speed spicer transmission and rockwell transfer case? Looks like I could just drop a multifuel engine right in, just changing the mounts, re routing the exhaust to a stack, changing fuel tanks, and guage/control linkages in cab? I am no expert in engine swaps by any means. I can get the 465 turbo engine for around $1500. Wondering if this is more trouble than it is worth to get a M35A2 work truck.
This thread has helped me get an idea of what to expect. Got tired just reading it!
Yes.Well planning on the swap with my M108. Finally got a good donor truck. Is the front cross member that needs to be changed the same on winch and non winch truck?
Well, today my goal was to get the replacement engine painted and ready for the future install. Also wanted to get the multifuel front crossmember sandblsted and painted. Well, got all that done and it was just after lunch so I started the engine removal process. Attached are a few pics of what I got done today.
