twisted60
- 246
- 43
- Jupiter, Florida
The side marker lights were new truck lite units purchased off "the bay", looking close it does say model 30 on the lens.
Yea thats what i put on mine. 3 diode. Like $20 for each light. Mounting bracket and pigtailThe side marker lights were new truck lite units purchased off "the bay", looking close it does say model 30 on the lens.
I'm glad to see she is well loved and getting some good ole' TLC.Finished installing LED turn and tail/stop light, already installed the side LED markers.
View attachment 664472View attachment 664473View attachment 664474
Tomorrow I'll install my new exhaust from TMG, and do a little write up.
ANy of your cans caged? I believe the light comes on if even one of your brakes has the caged bolt in.Got my new exhaust from TMG installed today, she has a deep throaty sound now, only gone on a quick test run but I do believe my EGT has dropped a little.
Second mission today was to change my little black ABS box, got it changed and my ABS light went out after 2-3 seconds of power on, I was on a roll, or was I ??? Nope, ABS light came back on in less than 1/2 mile into my test run. Started engine, pulled out of driveway, turned right, drove straight and bam ABS light came on, no power down just normal driving, Volt meter is running just into the green and stays steady so that rules out a voltage spike. Anybody have an idea ?
It's a wide flood beam with no hot spot. It has High and Low for area lighting and close up work. Grote doesn't specify run time but I intend to find out. One website selling them said 6 hours but didn't specify whether on High or Low. The magnetic base is super stong. It comes with vehicle and wall chargers. $54 at TruckPro...using an account.HA! I saw that little bugger on egay and thought about you. Hows the beam spread and battery life?
Is that thing an LED light of some kind?HA! I saw that little bugger on egay and thought about you. Hows the beam spread and battery life?
The ABS module grounds through a connection bolted to the PCB mounting studs. These are on metal standoffs that I have found with paint on them. This causes a floating ground problem. Check all of those ground points well, you will have to take them off to verify they are free of paint.Second mission today was to change my little black ABS box, got it changed and my ABS light went out after 2-3 seconds of power on, I was on a roll, or was I ??? Nope, ABS light came back on in less than 1/2 mile into my test run. Started engine, pulled out of driveway, turned right, drove straight and bam ABS light came on, no power down just normal driving, Volt meter is running just into the green and stays steady so that rules out a voltage spike. Anybody have an idea ?
NAPA Commercial #7237What are those batteries Swamp? Hawkers?
Those are group 31 commercial batteries from napaWhat are those batteries Swamp? Hawkers?
In case it is close for others what I did is I took a piece of the rubber play mats you can buy for kids play areas and cut it down to fit. One mat fits perfectly on top of all 4 batteries and protects from the lid of the battery box.Warning: For those who might go to these batteries, they will be within 1/4" of contacting the lid of the battery box. The wood spacers under the batteries are double stacked, then glued together. Take them out and split them apart. This will give you plenty of room on the top.
