I've always thought that this was a good independent test done on additives. http://www.dieselplace.com/forum/76.../177728-lubricity-additive-study-results.html
I remember as a kid in the 60s the smell of the city transit busses running the high sulfur fuels. It smelled distinctly good at the time. Maybe that's why I got hooked on tobacco for the past 40+ years.Well I read the whole article and the companion article. First, there was no mention of "older" diesels (Pre 1999) in the companion article. Second the tests referenced where from 1999. They used the "scuffing load ball test" which was discredited over 10 years ago. Third this whole article was from a third world country (South Africa) . Personally I do not trust any "Tests" done by a third world country.
Now I personally don't use 2 stroke oil in any of my diesel engines. It was not designed for diesel fuel. I personally use "Opti-Lube XPD" in all my diesel fuel. It is well documented to "help" increase lubricity in the injection pump.
Now for those who do not believe in using any additives in their CUCV, I would point to "Stanadyne" who makes a great fuel additive and by the way is the "Manufacture" of the injection pump used in the 6.2 diesel engine. Why in the world would the manufacture of the injection pump say to add anything to the fuel if that fuel was OK ? Just saying.
Now if your running a modern diesel engine there is no need to add anything to the fuel. The injection system has been designed to handle "Ultra Low Sulpher Diesel Fuel" . Just a reminder to all. ULSD has only 15 ppm of sulpher while the older fuel in the 1980s had over 2000 ppm of Sulpher.
Some use Diesel Kleen or whatever
Do the MSDS on it
Maybe just goto H~depot and get a gallon can of naphtha and put it with a full tank of whatever.
Can't hurt. worked for me.
Perhaps this is not what this thread is about.
Thgis is just a cut and copy
but the information is there
Re: Cheapest way to Increase Octane?
I was thinking the same thing.Hmmm. I'm not sure why you'd want to increase the octane rating on diesel fuel....
I agree, this was a well done study. Note that it had to be done by "private" individuals. The fuel companies would never do a study like this as they know the outcome already. I posted an article from the "Independent Fuel Station Association" (which my best friend belongs to since he owns a gas station) on the Deuce forum. In this article they where talking about the newer motor oils that meet the new emissions standards. The oil companies knew the oil was bad on older tappet cam engines and gave advice to the station owners on how to "deflect" car owners from suing due to engine damage. This information never came to light for the general public of course, but all us diesel mechanics knew about it. The same has happened with diesel fuel. Spin the information until all the older engines are gone, then there is no worries ! Makes a person extremely angry, but what can you do ? They have the media in their pockets and the blessing of the Government since it was the government which forced the change. There is correct information out there but you need to dig for it, and if you post it you will have a ton of payed "Trolls" dispute it all day long. It's the world we live in now.I've always thought that this was a good independent test done on additives. http://www.dieselplace.com/forum/76.../177728-lubricity-additive-study-results.html
I believe with diesel it is cetane. the higher the cetane the easier to ignite and the better it will run. But the higher the cetane the energy denseness is less.Hmmm. I'm not sure why you'd want to increase the octane rating on diesel fuel....
A lot of truth to this! I don't trust anything coming from any of the big oil companies. I learned first hand how bad the new oils were in my previous truck. I had a low mileage '71 GMC, all original and unmolested. Using the new oils I started having problems keeping the valves in adjustment. One by one the lobes on the cam went south and after estimating what a complete rebuild would cost I decided it was cheaper to buy a GM crate engine. Before I installed it I got to researching oils because I didn't want issues. That's when I found out the new oils have extremely little zink in them, which helps lube the cam lobes. I started running Bred Penn in it, definitely not eco friendly oil but it had the highest zink content I could find and would ensure the cam survived.I agree, this was a well done study. Note that it had to be done by "private" individuals. The fuel companies would never do a study like this as they know the outcome already. I posted an article from the "Independent Fuel Station Association" (which my best friend belongs to since he owns a gas station) on the Deuce forum. In this article they where talking about the newer motor oils that meet the new emissions standards. The oil companies knew the oil was bad on older tappet cam engines and gave advice to the station owners on how to "deflect" car owners from suing due to engine damage. This information never came to light for the general public of course, but all us diesel mechanics knew about it. The same has happened with diesel fuel. Spin the information until all the older engines are gone, then there is no worries ! Makes a person extremely angry, but what can you do ? They have the media in their pockets and the blessing of the Government since it was the government which forced the change. There is correct information out there but you need to dig for it, and if you post it you will have a ton of payed "Trolls" dispute it all day long. It's the world we live in now.
Agreed, I use 15w40 Rotella, and change the oil every 3000 to 4000 miles. Flat tappet engines will be destroyed by the new oils lacking Zink. Not sure about our 6.2's sense they have roller cams, but I figured why risk it.Rotella has plenty of zinc in it.
I use the MAXX brand myself but basically they are the same. Just remember to follow the directions for use. As has been mentioned already, too much zinc can cause other problems.Not TOO far off topic, I hope, but does anyone have any experience with this stuff:
ZDDPLUS7176 Zinc/Phosphorous Additive for Oil Concentrate
I have noticed the plain HD Diesel 15w-40 oil is getting harder to find. I’ve stashed 20 gallons of it as I’ve found it at Tractor supply and through Amazon. Even local (to my farm) Walmart’s not stocking it in favor of the newer varieties.
Some alphabet agency get their marching orders to remove zinc/sulfur-containing oils off the market?
Norm
