That is a very good transmission.My 1999 7.3 has a six speed ZF Trans.
i dont like the 1 piece wheels but thats just me. Why would you dump beadlocks? I understand not wanting to run the split rims as most folks around here wont touch them.and my one piece wheels, which i am looking for 1 or 2(one rim is messed up and i don't have a spare) unless i find a set of g177 then ill go duals which id rather.
The second Picture is the messed up wheel. You can see the piece welded in the center.
On your g177 tires get with Wes. He sent me pics with plenty of 177 tires in them. Im very happy with what i payed for 395's
You are all aware how hard zf parts are to come by now and it will only get worse. Just did a clutch on powerstroke with a zf6. Took some serious hunting to find the clutch fork. And even a pivot ball (ford uses stupid plastic) wasnt easy to find around here.
Could you post a picture of the jack-shaft and transfer-case ? Also pictures of the engine mounts would be great.Here’s the trans mission. I currently have the truck tore apart for a new frame. So if you want to see something let me know cuz all the sheet metal is off it .
I am also interested in these pictures. I will be installing a Cummins soon in my M135 and would like to see how Uncle Sam carried it out on your truck.Could you post a picture of the jack-shaft and transfer-case ? Also pictures of the engine mounts would be great.
Thanks.
I know this is an older thread but do you have any more pictures of the transmission & engine mounting of this setup.Here’s the trans mission. I currently have the truck tore apart for a new frame. So if you want to see something let me know cuz all the sheet metal is off it .
Negative. The Canadian M35 version used the Detroit 8.2 "Fuel Pincher" and the huge Allison MT643 auto.I thought at one time there were some Canada m35s
With Cummins engines ?
