74M35A2
- 340
- 83
- Livonia, MI
Is this the shift diagram for the pump????
Thats awesome, about made me spit my corn flakes out!
Love it (picture). I just like to guess at everything, and fool everybody. Most people just think I’m an a$$, not a community treasure.I may just hit you up on that. This option is still better than a 24v power unit mounted in the toolbox.
You are a wealth of knowledge and an asset to this community.
Ill draw you a picture if you don’t understand.
Gpm = speed. You can run a 5 ton winch on a 6hp 1 cylinder diesel engine. It will be just slow.so it will run the 5 ton winch tho correct? found this other pump that has a higher out put so might be better
3.9 Amps will never run a 5 ton winch!so it will run the 5 ton winch tho correct? found this other pump that has a higher out put so might be better
