- 463
- 262
- 63
- Seville, OH
The A1 and A1R originally have some sound insulation “paint” on the back wall inside . It’s different from the A0 Cabs that are just bare metal. If you press it with your nail you feel it’s somewhat soft.Starting to insulate the cab (aka the 94 dB EZ Bake Oven), starting with Lizard Skin sound control; ceramic insulation next week for heat, then some Dynamat hood liner. The Lizard Skin is easy to apply, and easy to clean up (water based). So far, seems to really work based on just a "tap test" (rap on an uninsulated steel panel - great steel drum effect. Rap on the Lizard Skin - very muffled thud). I might also spray the back wall of the cab and the roof inside - those are both big sound and heat radiators. Have some Kilmat for doors and other interior, as well. After getting that all done, will do another road test with the sound level meter to see how it does.
Nice!Installed troop seat seat belts for a customer today using some M35 MWO kits I had. It worked perfect and folds out of the way too.
Half planning and half luck.Nice!
Were they designed to tuck away like that, or did you just get lucky?
That looks great, I am doing the same to mine starting Tuesday. Curios, why did you tape off the rubber flaps instead of drilling the rivets out?Starting to insulate the cab (aka the 94 dB EZ Bake Oven), starting with Lizard Skin sound control; ceramic insulation next week for heat, then some Dynamat hood liner. The Lizard Skin is easy to apply, and easy to clean up (water based). So far, seems to really work based on just a "tap test" (rap on an uninsulated steel panel - great steel drum effect. Rap on the Lizard Skin - very muffled thud). I might also spray the back wall of the cab and the roof inside - those are both big sound and heat radiators. Have some Kilmat for doors and other interior, as well. After getting that all done, will do another road test with the sound level meter to see how it does.
Sorry for delay, was offline for a bit. No particular reason, it just seemed easier to do it that way. Overall, it turned out well. Haven't had a chance to get some actual measurements, but so far sounds a lot quieter.That looks great, I am doing the same to mine starting Tuesday. Curios, why did you tape off the rubber flaps instead of drilling the rivets out?
You can never have TOO much Aloha.I added a Hula Girl!
I stuck my lady to a hard drive magnet so hopefully she stays there.Nice, I also put one up there but the heat from the heater soften up the glue and she fell off. Rest In Peace; Hula girl.
Ok, finally got the Dynamat hood liner installed (thanks to a great video guide by Dave AndersonStarting to insulate the cab (aka the 94 dB EZ Bake Oven), starting with Lizard Skin sound control; ceramic insulation next week for heat, then some Dynamat hood liner. The Lizard Skin is easy to apply, and easy to clean up (water based). So far, seems to really work based on just a "tap test" (rap on an uninsulated steel panel - great steel drum effect. Rap on the Lizard Skin - very muffled thud). I might also spray the back wall of the cab and the roof inside - those are both big sound and heat radiators. Have some Kilmat for doors and other interior, as well. After getting that all done, will do another road test with the sound level meter to see how it does.
18 minute vid goes way past my attention span (I'm lazy, I admit it).
