LMTV Air Conditioner
ramdough
1,730
Austin, Texas
Spacers?
I read through a few times, but missed some info.
There needs to be washers used on the 3116 engines between the front cover and the bracket.
How thick are they?
On the main pulley, there was mention of needing a spacer so the fan bolts don’t rub. Where do the spacers go and what do they look like?
Any pictures?
Thanks!
Juanri23
Spain
[QUOTE = "blhar15, publicación: 1635653, miembro: 41378"]
Hemos instalado un par de unidades de A / C en LMTV. Esto requerirá la unidad del condensador, el compresor de A / C, algunas líneas hechas a medida, soportes para montar el compresor y la polea del cigüeñal delantera para hacer funcionar la correa para el compresor. Tuvimos que personalizar los soportes y la polea delantera. Si alguien está interesado, probablemente pueda hacer otro set, aunque no estoy seguro del costo.
[/CITAR]
I'm interested , can tell me if you are able to do it and how much will be? Thank you very much
coachgeo
3,480
North of Cincy OH
Not sure how this ended up in spanish..... but for others here is blhar15's post translated
We have installed a couple of A / C units in LMTV. This will require the condenser unit, the A / C compressor, some custom-made lines, supports for mounting the compressor and the front crankshaft pulley to operate the compressor belt. We had to customize the brackets and the front pulley. If someone is interested, I can probably do another set, although I'm not sure of the cost.
Juanri23
Spain
[QUOTE = "coachgeo, publicación: 2259320, miembro: 24293"]
No estoy seguro de cómo terminó esto en español ... pero para otros aquí está traducida la publicación de blhar15
[/ CITAR]
sorry I wrote in Spanish? If so, I'm sorry, error. the truth that interests me I will look at the post you say, thanks
